Old 17-03-09, 05:13 PM   #1
pencil shavings
Default engine/cluth slip around 8K revs
just been out for a ride after changing my oil (checked the level since ive been back home and its just below the full line, so looks ok and everything is where it should be and no leaks) and i noticed a slip in somthing when the revs got to 8K, the power didnt want to come and the bike didnt want to rev. I didnt notice this at the start of the ride, was about after 20miles.
Before I noticed this is was thinking how much differance the oil change makes and how nice and free the bike was reving.
what do you guys think?
Old 17-03-09, 05:25 PM   #2
Baph
Default Re: engine/cluth slip around 8K revs
You didn't use car oil did you?
Other than that, check your clutch adjustment. I've had similar when I wrongly adjusted the clutch in a hurry, went to overtake a truck in an NSL, and the bike crawled past him revving it's nuts off.
Old 17-03-09, 05:27 PM   #3
gettin2dizzy
Car oil was my first thought too
Old 17-03-09, 05:28 PM   #4
pencil shavings
nope but I did adjust the clutch
I will readjust it and hopfully it will be ok
I thought it might be that tbh but I dont know how or why it would have affected anything??
Old 17-03-09, 05:53 PM   #5
pencil shavings
just adjusted the clutch, went to start it and...
nothing
the bike primes like it should, just nothing when you press the starter
Old 17-03-09, 06:03 PM   #6
sinbad
Have you disturbed the clutch switch wires (I think they're just below the adjuster on the lever)?
Old 17-03-09, 06:08 PM   #7
pencil shavings
on the actual clutch lever?
Old 17-03-09, 06:58 PM   #8
sinbad
If you look just beneath the adjuster on the bar lever you'll see two little wires and a connector.
I'm not saying it definitely is this, but it sounds possible.
Old 17-03-09, 07:13 PM   #9
pencil shavings
cheers, i will look
I adjusted it both at the lever and at the worm drive, so might be.
Old 18-03-09, 04:50 PM   #10
pencil shavings
cheers sinbad, they had come loose. such a minor thing, but if the you (the .org) werent here to help life would have been so much harder!!
im off now to see if the reajusted clutch prevents the 8k slip!
Idle Revs Draper SV Talk, Tuning & Tweaking 19 29-10-07 08:03 PM
how do you lot ride what revs jans1971 Bikes - Talk & Issues 20 05-09-07 07:04 AM
FI light comes on and engine over revs scorpion SV Talk, Tuning & Tweaking 1 18-04-07 07:36 AM
8k revs and nothing happens!!!! help vsumouse SV Talk, Tuning & Tweaking 15 28-01-07 03:51 PM
Cluth Levers MarkyBoy SV Talk, Tuning & Tweaking 5 11-08-05 04:26 PM
