Anyone one here got a shock with a remote reservoir for their road bike? Just wondering where you have it mounted and if you've just lashed it on or have a mounting bracket.
Depends on the model of SV. Which one have you got?
I had mine mounted just behind the shock and cable tied to the stock undertray through a couple of holes I drilled. Didn't make sense to me to have it on display where some little chodder could mess with it.
It's mounted in the same place on my S4 now too. |
One of the handle things that is just underneath the tail piece (curvy). Ohlins came with mounting blocks and two stainless jubilee clips, though vibration did for one so using a cable tie
In that case as Johnny_Rod says, most fix to the bungy rails under the pillion area of the tailpiece.
Favourite Place? | sv_rory | Idle Banter | 11 | 01-12-08 02:47 PM |
Shock Lower Mounting Bolt (For Pointy 650) | Bez | Stuff Wanted | 0 | 28-10-07 02:36 PM |
SRAD rear brake reservoir mounting | svrash | SV Talk, Tuning & Tweaking | 1 | 31-10-06 06:31 PM |
brake reservoir cap | toffo | Stuff Wanted | 0 | 27-07-06 03:48 PM |
Uprating the shock and mounting the battery | Jase22 | SV Talk, Tuning & Tweaking | 20 | 12-01-06 10:06 AM |
