Okay peeps...
As everyone is well aware, there are certain modifications you can do to an sv to make it suitable for the shorter legged rider. Can you therefore do the opposite?? I would desperately love to keep the Evil Raspberry, but due to my long inside leg and previous crash injuries getting worse...I need MORE leg room between the seat and the pegs. Is this possible without de-stablizing the ride?? How would this be possible? Has anyone done it successfully? Also the next thing I'd do is raise the handlebars with bar risers (for which I've already found out what to get and where from). This seems the only viable option in order for me to keep the Raspberry, and not sell her... ![]() |
You can lower the pegs with some adapter plates. You'd reduce ground clearance, but it could give you the room you need.
THey look like this ![]() |
And you can fit Buell footrests, they are slightly offset and lower about an inch, add that to the plates mentioned above and you could possibly lower the pegs two inches.
Trinity
So for the avoidance of doubt, and given the esteemed posters above didn't mention it, shorter dogbones to jack up the rear won't actually increase the seat to peg lenth?
![]() *not really but someone might be mistaken ![]() edit Actually I reckon it would, although the more pronounced affect would be towards the rear. Clanger have you got a K3* already *the tall one Last edited by Stu; 21-03-09 at 11:12 AM. |
#5 | |
I'm pretty sure the overall seat height isn't the OP's problem, but they feel a little cramped whilst riding? Maybe stuff some more foam into the seat instead of cutting it out though. ![]() |
#6 | |
Can none of you twig a wind up when it's staring you in the moosh?
#9 |
silly question if you jacked up the rear then put the peg extenders on would that offset the clearance issue ?
#10 | |
Trinity
![]() ![]() G2D has a good explanation that the seat & pegs are both on the frame so move together with dog bones. Just one slight mistake as they move the front of the swing arm - you need a larger diameter wheel & tyre to raise the rear of the swing arm ![]() DaveP yes, lower the pegs then jack up with dog bones |
Select Reverse Gear............... | Cam_73 | SV Ecosse | 9 | 24-07-07 05:12 PM |
Intro and question regarding bike lowering | delpel | SV Talk, Tuning & Tweaking | 19 | 29-06-07 08:41 PM |
Reverse gear box shift | lukemillar | Bikes - Talk & Issues | 7 | 08-05-07 09:17 AM |
Humans are Reverse Evolving … | Blue_SV650S | Idle Banter | 100 | 26-01-07 03:48 PM |
Another strange question...bike won't reverse | Freeloader | SV Talk, Tuning & Tweaking | 6 | 23-01-06 08:00 PM |
