Old 23-03-09, 04:51 PM   #1
Magnum
Default What causes bike to slip out of gear?
My CG sometimes slips out of gear from second. It either slips down into neutral just after changing up from first, or in the worst case scenario it slips from second to first when riding along(which makes me sheet myself because the backwheel locks up).
I thought that maybe it was because of the way i was shifting, but this is something that has only happened over the last 500 miles and my style hasnt changed.
It's a little concerning since the slip down into first makes the bike extremely unstable.
Thanks for any help...
Old 23-03-09, 05:16 PM   #2
MrTom
Default Re: What causes bike to slip out of gear?
Global warming
Old 23-03-09, 05:20 PM   #3
thefallenangel
i done this this morning. At a point of gearing you can change gear without using a clutch so if your foot is resting a bit heavy on the lever it will drop down.
Old 23-03-09, 05:39 PM   #4
gettin2dizzy
Check oil level + chain adjustment
Old 23-03-09, 05:42 PM   #5
AmigaNut
When i had a CG as temp transport, mine developed a fault where it would not change up mainly 2nd on the 1st attempt.
That was due to a worn dog lever or whatever. There was a modified replacement for it. The bike was an N reg and i had it from new so wasn't abused.
AGV bike gear hovis Bikes - Talk & Issues 11 19-05-09 01:33 PM
Clutch slip in first gear and a gas smell stone SV Talk, Tuning & Tweaking 12 13-05-09 03:47 AM
bike gear hovis Riding Gear 2 07-10-06 11:24 PM
bike gear apoc76 Idle Banter 0 08-01-70 03:50 PM
