Old 23-03-09, 05:23 PM   #1
adamw2k2
Default Will jump starting damage my bike?
Hi all, came to start my bike today and the battery is completely drained, this is the first time I have tried to start it for a couple of weeks.
I have a couple of culprits as to what could have drained the bike (I have an alarm and heated grips).
My question is, I went to bump start it from a car battery today, connected the jump leads, turned on the ignition all the usual noises of the fuel pump running etc. pressed the ignition then heard a click and all went dead. Now nothing will work on the bike, have checked all the fuses but they are all ok - any ideas what is wrong?
Thanks for any advice
Old 23-03-09, 05:33 PM   #2
chompy
Default Re: Will jump starting damage my bike?
did you put the leads the right way and did you have the car running first? maybe the fuel is low as well sit the bike up when you do it
charlie
Old 23-03-09, 05:39 PM   #3
gettin2dizzy
There's a main fuse that is just in the middle of a wire under the pillion seat. Check this.
Old 23-03-09, 07:05 PM   #4
fatneck
Correct me if I'm wrong, but when jumping a bike from a car you shouldnt have the car running should you?
Old 23-03-09, 08:05 PM   #5
BigFootIsBlurry
BigFootIsBlurry's Avatar
I would not have had the car running.
Ain't no sunshine when she's gone...
2000 curvy, yellow and naked. Gone but not forgotten.
Last edited by BigFootIsBlurry; 23-03-09 at 08:22 PM. Reason: EDIT: wrote the opposite of what I meant
BigFootIsBlurry is offline   Reply With Quote
Old 23-03-09, 08:08 PM   #6
Dave20046
Dave20046's Avatar
As gettin2dizzy has said probably the main fuse. On a curvy it's on the brakes side of the bike under the black infill panel under the riders seat.
I always have and will do.
Old 23-03-09, 08:20 PM   #7
simesb
I've heard tell that you can damage the Reg/Rec but other say it's not a problem. I've done it both ways with no probs so far.
Car doesn't need to be running cos the bike isn't going to drain that much juice....
Old 23-03-09, 09:35 PM   #8
matt_rehm_hext
I've jump started my pointy SV from my CG125 a few times when the battery was completely dead, that worked fine, I had to keep the CG's revs up for a minute or two to charge the battery a bit before trying to start.
Now I gots an optimate )
Old 23-03-09, 09:36 PM   #9
fatneck
Optimate is where its at, oh yes. Just wish I had power in the garage
Old 23-03-09, 09:37 PM   #10
matt_rehm_hext
I keep my bikes in the garden, and I run the cable out the back door. Its not ideal but the cable isn't getting squashed too much. When i got time i'm going to install the optimate inside the kitchen and the cable will come out through a vent in the wall.
Jump starting an SV650? Mej SV Talk, Tuning & Tweaking 31 05-12-08 06:48 PM
Jump Starting? DarrenChay SV Talk, Tuning & Tweaking 7 12-11-08 01:13 PM
Jump starting an SV? thumper21 SV Talk, Tuning & Tweaking 20 03-04-08 08:24 AM
Jump starting a curvy - advice needed quick! FreshAL SV Talk, Tuning & Tweaking 15 01-04-08 09:27 PM
Can i jump start my bike with jump leads (Like my car!) Freeloader SV Talk, Tuning & Tweaking 3 08-12-05 06:46 PM
