Old 03-04-09, 12:34 PM   #1
Owenski
Default Oil Burning when cold.
To get you up to speed:
On start up (mainly morning starts) its stinks like the oil is burning.
First thought was to change the oil, so I did... changed the filter too just for good measure. So again I use the bike and find that on a cold start there is a LOT of smoke and burning oil.
Oil is new, Filter is new, Choke switch is functioning correctly, Oil levels are between F and E lines.
Any ideas what may be causing it? It was embarrasing this morning when I pulled up at the bottom of the road an was caught up by a white cloud of smoke shortly after.
Old 03-04-09, 12:39 PM   #2
Default Re: Oil Burning when cold.
Piston rings, compression test time.
Old 03-04-09, 12:42 PM   #3
cymroboi
cymroboi's Avatar
have you checked the air filter ?????
2003 triumph S4
2002 sv 650
cymroboi is offline   Reply With Quote
Old 03-04-09, 12:48 PM   #4
Owenski
No, your navigator pic is quality
Old 03-04-09, 12:51 PM   #5
cymroboi
cymroboi's Avatar
i used to have a similar problem with my old gasgas tx 280 ,not saying it is that but get it checked first ,dose it clear up after it gets warm ????
yes thats what you call a proper hot dog lol
2003 triumph S4
2002 sv 650
Old 03-04-09, 12:56 PM   #6
Owenski
Seems to clear up, ie when I get home I've forgotten about it.
Old 03-04-09, 12:56 PM   #7
Owenski
YC, how would I check that stuff out?
Old 03-04-09, 12:58 PM   #8
Owenski
If it helps the fireing pops arnt contant its not like a regular missfire or anything its just when its on idle tick over is sometimes seems to fire twice really quick.
Old 03-04-09, 02:13 PM   #9
Compression test is easy but you need a compression tester. (I need to get myself one after mine went walkabout)
Leakdown test would also do the trick. I'll see about building another tester if you wanna pop over to Hfax?
Old 03-04-09, 02:24 PM   #10
Owenski
That'd be fantastic mate cheers, it'll be a while off though.
Building this weekend and away next so when ever your free 18th onwards then I'll make the trip. PM me details
using / burning oil DOM B Bikes - Talk & Issues 8 11-05-09 08:31 PM
Burning oil yorkie_chris SV Talk, Tuning & Tweaking 10 02-12-07 05:21 PM
burning oil auldyin SV Talk, Tuning & Tweaking 4 26-07-06 06:05 PM
Burning? Full Throttle SV Talk, Tuning & Tweaking 4 21-03-06 11:34 PM
Burning too much oil. Redi_Jedi SV Talk, Tuning & Tweaking 22 08-02-05 03:53 PM
