Old 08-04-09, 12:56 PM   #1
arcdef
Default Rear axle nut alternatives?
Im after a stainless steel rear axle nut and have found this, is there anywhere else i can get it from cheaper as it is a very expensive nut, have checked Chewys stuff with no luck,
any help would be great.
Cheers,
Ash.
Old 08-04-09, 01:01 PM   #2
timwilky
timwilky's Avatar
Default Re: Rear axle nut...
with the crazy torques 110NM on these. I would not consider an aluminium nut
Not Grumpy, opinionated.
Old 08-04-09, 01:02 PM   #3
arcdef
any suggestions then as my nut is rusted to hell and back and dont fancy wasting money on another nut that will rust, torque isnt that high on a curvy btw
Old 08-04-09, 01:04 PM   #4
arcdef
or i could use one of these as they are titanium, but i dont know the nut size and its even more £££s
Old 08-04-09, 01:31 PM   #5
Default Re: Rear axle nut alternatives?
It's not 110NM on the curvy.
I wouldn't bother, what's the point?
Old 08-04-09, 01:51 PM   #6
Geoffrey
http://www.tastynuts.com/site/frames...shoponline.htm
select your bike and scroll down the list
Old 08-04-09, 01:53 PM   #7
timwilky
timwilky's Avatar
Yes only 65 for the curvy, should have looked at your avatar. Still I would not use an aluminium one even at that torque.
The only argument would be reduce unsprung weight, and weight saved is so minuscule that it would achieve sod all. if the one you have is so corroded, buy a new one.
Old 08-04-09, 01:56 PM   #8
Wire brush the original and wipe it over with WD40 or similar.
This will cost approximately 0.003675p - give or take.
Old 08-04-09, 02:11 PM   #9
johnnyrod
johnnyrod's Avatar
Get a new one and have it chromed. It'll rust in the end but really, if it's that big a deal, don't ride it in the wet.
Old 08-04-09, 02:18 PM   #10
petevtwin650
Buy a titanium one from Probolt/Tasty nuts. Just don't bother to get a coloured one as the colour will eventually polish away.
Includes the washer so you can bin that too.
Only a tenner (or it was when I bought mine) and you really can feel the difference. Honest
Rear wheel axle nut sweepdoggydog Stuff Wanted 0 25-04-09 07:47 PM
Rear Axle Torque Setting K6 Hardened Rider SV Talk, Tuning & Tweaking 3 01-09-08 09:51 AM
Rear Brake Alternatives Tris SV Talk, Tuning & Tweaking 5 11-03-07 11:48 PM
my bike, clear alternatives rear lights. hall13uk Photos 19 28-04-06 10:16 PM
What is the size of the Rear Axle nut? mordecai SV Talk, Tuning & Tweaking 4 02-05-05 07:57 PM
