As above, I bought the castle nut tool off ebay but didn't realise I need a massive hexagon bit too...
I'll collect and bring it back, or you're welcome to pop round for a brew and a chinwag... Also, what grease should I use on re-assembly of the swingarm? Lithium? Something else? |
probably lithium don't quote me on that though. I use castrol high temp l&m bearing grease (IIRC)
The socket size is 19 on one side and 17 on the other (I think) can never remember. Have you a large adjustable spanner you could have a gentle go with? or use mole grips or something to hold the 19mm side and try and undo it at the 17mm side (bit bodgey though). Good luck
![]() Last edited by Dave20046; 12-04-09 at 03:18 PM. |
halfords?
i got a 24mm socket for my back wheel from ebay |
Do you mean a socket or a 19mm allen key?
it's basically a 19mm allen key but you can get them in socket form:
I got a 12mm for the front wheel axle from halfords but they didn't have any as big as 19mm... It's recessed into the frame and the outer edge is threaded for the castle nut so I can't grab it with anything. |
saw a piece of a 19mm allen key and use it with a 19mm socket! might work
hi matey, where abouts are you? 19mm allen key! thats pretty big.
how about getting yourself a bolt (19mm) using vice grips, grip the threaded part insert the 19mm hexagonal head, grip an twist! any problems give me a shout mucka, i am in salford, be no trouble to give you a lift. |
#9 |
19mm is huge - my set only goes up to 17mm.
#10 |
hmm...
http://www.mewillis.co.uk/DetailProd...p?StkNum=10961 that should fit one end in a 19mm socket and I can use the other end in the swingarm pivot bolt... |
heaton park, manc. | Gene genie | Pennine Massive | 6 | 11-07-09 09:42 PM |
Any body about south Manc | Ratty | Idle Banter | 8 | 18-09-08 11:06 PM |
Cheap tyres in the Manc area? | Razor | Pennine Massive | 6 | 26-07-07 07:21 AM |
Run out Sat pm. South Manc area. | Ratty | Idle Banter | 7 | 24-06-07 09:32 PM |
Paint shop around Manc. | BURNER | Pennine Massive | 21 | 06-02-05 07:28 PM |
