Old 15-04-09, 11:45 AM   #1
simon260591
Smile front suspension
hi
i feel that my front suspension is to soft when i really push it hard in the bends. does any1 else feel the same about theres? its a K8 sv650s. and what do people fink about making it harder would its help or just make it worse. the rear suspension feel fine if i decide to harden the front will this affect the rear aswell?
thanks
simon
Old 15-04-09, 11:53 AM   #2
DaveW_42
DaveW_42's Avatar
Default Re: front suspension
go for some hyperpro progressive springs. Much better
DaveW_42 is offline   Reply With Quote
Old 15-04-09, 12:00 PM   #3
charlie13
have a search through, there's ton's of opinions and different advice here somewhere. i really liked the white power progressive springs and 20W oil that I put on my curvy. still hasn't stopped me tinkering to get a set of gsxr forks on in the near future tho.
Old 15-04-09, 12:08 PM   #4
Mr Speirs
Mr Speirs's Avatar
How hard are you pushing it in the bends? How much do you weigh?
People including me have stiffened up the suspension and it has helped although I think I did a bit too much to mine so went for 15W fork oil and slackened off the emulators a bit. This has helped in as much as high speed rides are really nice but it is still bumpy low speed (solution...always ride hard)
Anywhoooo....Progressive springs seems to be the easiest and cheapest fix.
That is what I 'fink'
Old 15-04-09, 12:15 PM   #5
simon260591
i only weight 10 and half stone. its fine on a nomal ride out but soon as start to go for it the front end deos'nt like it at all its in the tight bends i notice it most. might have to look into some new springs if just hardening it up does'nt work.
Old 15-04-09, 12:28 PM   #6
skeetly
skeetly's Avatar
I'm 12 stone. Hagon progressives with their prescribed 5w oil.
I have had a zip tie around the fork leg since doing them a while back and that includes one track day and I still have about 25mm of stanchion left before the bottom of the yoke. Big improvement over 6 year old fork oil and standard springs.
I don't class myself as a 'hard' rider though.....
skeetly is offline   Reply With Quote
Old 15-04-09, 12:28 PM   #7
Mr Speirs
Mr Speirs's Avatar
I believe the bike is sprung for someone your weight anyways. Maybe try replacing the oil for 15W for now and see how you get on with that?
What do you feel like it is doing in the tight bends?
Old 15-04-09, 06:28 PM   #8
Old Git
Old Git's Avatar
Have K1 curvy, had stock front end until Sunday, changed for progressive springs & 15w oil, huge difference, used to dive under breaking so much was getting scrapes on my nose.( But I have eaten all the pies before though, so stock was being asked to do a lot of work!)
Went out after the change & can push it much more, easily better into & through the corners, much more confidence building.
Old Git is offline   Reply With Quote
Old 15-04-09, 06:36 PM   #9
Neeja
I've got a set of hagon progressives along with 20w oil in my front. I weigh about 10.5st, and it's fantastic. No diving under breaking, the front-end doesn't skitter or try to wash out under hard cornering, and the bike feels very planted. It's a moderately hard ride with 20w, but not uncomfortably so.
Old 15-04-09, 07:08 PM   #10
zunkus
Mine's sorted look me up.
Need advice on front suspension FishyMug SV Talk, Tuning & Tweaking 9 05-07-07 09:28 AM
Front suspension Fuzz SV Talk, Tuning & Tweaking 14 03-05-06 11:56 AM
Front Suspension settings MarkyBoy SV Talk, Tuning & Tweaking 9 06-08-05 06:06 PM
Front Suspension chris SVK3 SV Talk, Tuning & Tweaking 16 22-01-05 10:37 AM
FRONT SUSPENSION UPGRADE jessie SV Talk, Tuning & Tweaking 11 12-11-04 09:22 AM
