Old 17-04-09, 05:34 PM   #1
dmracing
Default Problem, need help as usual!!
Right, during my soaking wet ride home the bike (SVS K5) started to coff and splutter. For the rest of the journey it seemed like it was only running on one cylinder. My guess is that the front spark plug is wet, but I am no expert so if anyone knows what is going one, here is my problem...
  • It started to coff and splutter after about 20 minutes of city riding in the rain.
  • To keep it running I had to hold the throttle open and slip the clutch at slow speed.
  • On the motorway, the bike seemed to feel just like a car that was trying to go up a hill in a way to high gear
  • On slow roads leading to my house it kept on jolting back to normal for a split second.
  • It made it home and was ticking over below the 1,000rpm mark sounding very lumpy.
Please help me point out the problem and find a solution.
Cheers guys!!!
Old 17-04-09, 05:36 PM   #2
fizzwheel
fizzwheel's Avatar
Default Re: Problem, need help as usual!!
First thing I'd do would be to remove the front spark plug and dry it out, I suspect thats what your problem is and if its not well you've eliminated one possibility anyway...
Old 17-04-09, 05:42 PM   #3
JamesMio
+1 with the Fizzmeister, that sounds very much like the soggy front plug syndrome. Get the plug out, dry it out & stick a splodge of silicon grease around the plug cover to keep it dry in future. We've all had this at one point I think!
"That **** on the push-bike."
Creatomatic
Old 17-04-09, 05:46 PM   #4
2hys
then get yourself a fender extender worth the money, ive never had a problem with wet plugs and i do alot of wet riding
Old 17-04-09, 05:50 PM   #5
rictus01
rictus01's Avatar
to save a bit of time, first thing I'd do is get a bit if stiff wire and clear the front cylinder drain hole, if by doing that water comes out, then it'll show you that's the problem, takes all of a minute or so, and you don't need anything except the afore mentioned bit of wire.
Cheers Mark.
Old 17-04-09, 05:51 PM   #6
fizzwheel
fizzwheel's Avatar
If you cant find a bit of wire, then the little red tube that comes with a tin of WD40 works quite well on the drain hole as well.
Old 17-04-09, 06:02 PM   #7
Jamiebridges123
Only around £20 inc postage as well!
Old 17-04-09, 06:05 PM   #8
dmracing
Ok, stupid question, where is the drain hole???
Old 17-04-09, 06:06 PM   #9
fizzwheel
fizzwheel's Avatar
On the Right hand side of the front cylinder casing. Theres a very small hole and thats what you want to be making sure is clear so that water can drain away along it.
usual question Tara Guildford Massive 33 29-07-08 07:46 AM
Zorstsssssssss as usual! plowsie Exhausts 3 02-11-07 04:30 PM
Quick question bout the usual reg/rec problem Jay1 SV Talk, Tuning & Tweaking 12 30-09-07 10:53 PM
The usual! Jester666 Soho Massive 17 21-07-07 02:33 AM
NIP - The Usual Then 454697819 Idle Banter 31 12-06-05 02:47 PM
