Old 20-04-09, 10:02 AM   #1
sv_rory
Default Cam chain adjusters
I took the bike out yesterday and its started to sound a little cam chainey.
I am going to replace the adjusters, I have seen ones that you set manually, I think they were called ape adjusters?
Are these any good, or should I ask please could somebody reccomend a good set of adjusters that would fit my 2000 curvy.
Old 20-04-09, 10:05 AM   #2
husky03
Default Re: Cam chain adjusters
k3 ones are recommended i think-do a search on here it was mentioned not long ago
Old 20-04-09, 01:41 PM   #3
skyline
Yup K3 or K4 ones go straight on and will do the job much better than the standard curvy tensioners; the K5 on ones won't fit tho as they use an oil feed.
I want to do this same thing; I'm gearing up to have a shot at checking my valve clearances when the time comes and want to try replacing the tensioners then...
Old 21-04-09, 09:14 AM   #4
sv_rory
how easy are these to fit?
Is there any way of removing mine and checking for wear? can I tighten them up?
I'd much rather try and sort them out than replacing them
Old 21-04-09, 09:17 AM   #5
What's up with yours?
Taking them off is easy, it's holding them back to bolt back in that's the ticklish bit.
I am not convinced with manual ones, lots of stupid people just tighten them up until it shags the camchain.
Old 21-04-09, 01:26 PM   #6
sv_rory
In that case I will go for the ones of the k3 model.
Is there a special tool that is required to fit them?
Old 21-04-09, 01:27 PM   #7
drag
There like hen's teeth those K3 adapters...
Old 21-04-09, 01:33 PM   #8
Stig
When you buy them new they come with a little spade holder thing to keep the spring wound. Once inserted, remove the spade. I made one out of a bit of tin. Easy enough to do.
Old 21-04-09, 01:35 PM   #9
Ah cool didn't know they came with them.
I made one out of a bit of hacksaw blade
Old 21-04-09, 01:39 PM   #10
Stig
That is of course only if you are buying new.
Headlight adjusters? Bluepete SV Talk, Tuning & Tweaking 2 20-05-09 11:55 PM
Replacement chain adjusters lazymanc SV Talk, Tuning & Tweaking 0 08-04-09 12:03 PM
What do i need to convert the 1999 (no preload adjusters) to having preload adjusters and progressive springs. sv_rider1990 SV Talk, Tuning & Tweaking 12 11-07-08 05:15 PM
preload adjusters. scottjames SV Talk, Tuning & Tweaking 16 28-04-08 04:06 PM
Cam Chain adjusters, do they stick? gc350 SV Talk, Tuning & Tweaking 5 17-05-06 09:33 AM
