Old 20-04-09, 11:29 AM   #1
Ben_K
Default Ignition swtich plastic housing/casing
Hello all,
I took off the ignition switch yesterday and found the small plastic lug to be broken that stops it from rotating on the handlebar. Replacement cases are actually the whole unit and cost over £100! So, I will bodge it back together. I'd like to avoid Araldite or fully permanent solutions, if possible. How would you guys do it?
Thanks!
Old 20-04-09, 11:42 AM   #2
rictus01
rictus01's Avatar
Default Re: Ignition swtich plastic housing/casing
if you want a glue that'll pull apart (all be it with some effort), use something like Evostick.
Cheers Mark.
Curvy - Plastic Casing round the Throttle? JamesMio Stuff Wanted 7 19-12-08 12:32 PM
What plastic are the plastic bits made out of? Mark_h SV Talk, Tuning & Tweaking 3 24-03-08 08:32 PM
plastic clutch casing, cover thing UKStreetFighter Stuff Wanted 7 09-03-07 08:48 AM
K3-5 Fan housing jamesobrady Stuff Wanted 4 29-07-06 04:28 PM
Plastic / Fairing Repair (Plastic Welding) Solution MattP SV Talk, Tuning & Tweaking 2 29-06-06 04:14 PM
