Old 26-04-09, 09:47 PM   #1
chasey
Default Fork Spring Change - Tools
Next Sunday picking up some new springs for the SV. Just wondering what tools will I be needing? Hopefully going to get it done next Sunday aswell - making assumptions it's not going to take too long.
Do I need to take the forks out of the yokes and away from the bike or can I do it where they are now (on the bike ). What about things such as air gap?
I have not seen the instructions yet so maybe this will all become clear in those, however, I am wanting to make sure I have everything ready.
Had a quick look on the fourm but due to all the threads regarding fork spings was quite hard to find answers to my questions!
Ta for the help
Old 26-04-09, 09:51 PM   #2
suzsv650
Default Re: Fork Spring Change - Tools
Top quality socket set and some way of getting the front wheal off the floor should be about it tbh
Old 26-04-09, 09:53 PM   #3
chasey
Got & Got - well, if a car jack will do for the front wheel.
How much work am I looking at - going to get the fairings removed Saturday evening I think in preperation !
Old 26-04-09, 09:53 PM   #4
chasey
The car jack will be under the engine I hasten to add.
Old 26-04-09, 09:59 PM   #5
suzsv650
tbh you dont need to remove the fairings..i wouldnt bother
Forks out - Simples
Old springs out - Simples
New fork seals - anoying! - but you prob wont be doing this..?
Putting new fork springs in - simplily anoying - such a simple job but a pain in the ass due to compressing the spring to get the cap on
Jack under the engine is cool remeber a block of wood tho!
Old 26-04-09, 10:34 PM   #6
simesb
Don't need to take the fairings off. Clip-ons, three fork clamp bolts, and the big bugger for the pre-load/fork cap. All can be done with the fairing in place.
Old 27-04-09, 10:11 AM   #7
punyXpress
punyXpress's Avatar
Jack under the engine is cool remeber a block of wood tho![/quote]
Don't put it under oil filter ( but you probably knew that already )
Now: Street Triple R
Old 27-04-09, 10:58 AM   #8
timwilky
timwilky's Avatar
Air gap is model dependant. What model have you got
Not Grumpy, opinionated.
Old 27-04-09, 11:43 AM   #9
chasey
SV650S K1. What's best way to do the air gap? Would metal ruler type method word?
Sounds like it shouldn't be too tricky then and only a couple of hours worth of work at the most!
I wasn't planning on doing new fork seals - literally just swap springs and oil.
Old 27-04-09, 12:54 PM   #10
Air gap depends on springs used, your weight etc. and is highly dependant on personal preference.
A metal ruler is fine.
Price for fork spring/oil change glade SV Talk, Tuning & Tweaking 14 06-09-08 08:01 AM
Shock spring change andyb SV Talk, Tuning & Tweaking 2 23-03-08 03:51 PM
front spring oil change etc jon8oy SV Talk, Tuning & Tweaking 7 18-12-07 06:31 PM
curvy fork spring change help needed gregsv650 SV Talk, Tuning & Tweaking 1 14-10-07 10:03 AM
Folk Spring and oil Change Samurai SV Talk, Tuning & Tweaking 23 31-03-06 04:55 PM
