Old 05-05-09, 03:22 PM   #1
thor
Default Chain and Sprockets & X-ring vs o-ring?
How much and where?
Yes I did a search...
But I also saw something called an x-ring chain. What are they and why are they better than an o-ring chain?
Thanks in advance!
Old 05-05-09, 03:38 PM   #2
Default Re: Chain and Sprockets & X-ring vs o-ring?
They're both sealed chains, pick the one you like the colour of.
Grade is the important factor not seal shape.
Old 05-05-09, 03:48 PM   #3
Scoobs
Vipers Pillion Bitch
Scoobs's Avatar
Personally if the price is similar, I would go for an X over an O as there are more points of contact on an X, thus in theory, better sealing.
I look good, I mean really good! Hey everyone come and see how good I look!
Scoobs is offline   Reply With Quote
Old 05-05-09, 10:16 PM   #4
There may be some minor advantage to X rings if you don't bother yourself to such a menial task as lubing your chain.
Otherwise go for a good quality one. DID, tsubaki. And don't trouble yourself too much with the marketing spiel on the box...
Old 05-05-09, 10:27 PM   #5
davepreston
so why didnt you tell me to get an x ring then yc your slipping my lad
Old 05-05-09, 10:29 PM   #6
Because I also told you to stop being a lazy tw4t and lube the chain!
Such things will save you money...
Old 05-05-09, 10:30 PM   #7
xXBADGERXx
Tsubaki X-Ring and JT Carbon Steel Sprockets from B and C Express , comes in at around £105 with postage .... well it did last year when I got mine , done over 9k miles on it and it has been Scottoilered and showing no signs of needing replacing this year
Old 07-05-09, 07:25 PM   #8
thor
So what's the difference between these sets then?
Renthal Sprockets (Hard Ano rear) and Tsubaki X Ring Gold
3140.HA.APX
£ 110.40
Renthal Sprockets (Hard Ano rear) and Renthal X Ring Gold
3140.HA.SRS
£ 124.57
Renthal Sprockets and Tsubaki X Ring Gold
3140.RE.APX
£ 106.75
Steel Sprockets and Tsubaki O Ring
3140.ST.AP
£ 93.65
Steel Sprockets and Tsubaki X Ring Gold
3140.ST.APX
£ 100.00
Steel Sprockets and Tsubaki Economy O Ring
3140.ST.MG
£ 83.79
Old 07-05-09, 08:12 PM   #9
Tsubaki make several grades of 525 chain in o and X ring styles.
Also don't bother with alloy sprockets IMO, they're softer than steel and wear more quickly. Stick to JT steel sprockets.
Old 07-05-09, 09:38 PM   #10
xXBADGERXx
The Hard Anodised ones look quite pimp for a month or Two , then when they wear through the 50 Microns or so of Hard Anodising , they`ll get chewed through quicker than a stick in a Bulldog`s gob .
I have the Tsubaki X ring and JT Carbon Steel sprox and it`s still going strong , I reckon with good care I`ll get around 30k from the chain . Done over 9 on it already and have hardly had to adjust it , there is hardly any pull away from the rear Sprocket , the Sprockets themselves show a tiny bit of wear , no stiff links either . All down to my Scottoiler and the occasional clean down with paraffin to remove the thick winter gunk that built up on it .
Spa 7th Aug, Ring 8th/9th Aug Tim in Belgium Track Days 7 10-08-09 07:26 PM
Rock am Ring - anyone going?? Leopard_lily Idle Banter 0 21-05-09 06:43 AM
So I need some new ring spanners timwilky Idle Banter 23 09-02-09 11:51 AM
SSS X Ring Chain snoopy SV Talk, Tuning & Tweaking 7 24-04-05 08:38 PM
X Ring vs O ring Iansv SV Talk, Tuning & Tweaking 13 03-04-05 09:43 PM
