The Sick Man
Ive got to code up a tricky date calculating script, i dont do much with dates.
Ive got to calculate the folowing... Things i know, range type ie.. weekly/monthly/quart/yearly, i also have a period start date that all thoes ranges need to be keyed against which is based against the user. So ie if user has range setup as monthly i use the folowing calculation to work out the start date, it accounts for leap years and also feb/sep day diffrences. The year in the periodstart date is not used in these instances realy. Code:
$periodstart = "2007-05-04 00:00:00" $limdate = strtotime($periodstart); if(date("d",$limdate)>=date("d")){$month_offset=1;}else{$month_offset=0;} if(date("d",$limdate)>=date("d") && date("m")==1){$month=12;$year=date("Y")-1;}else{$month=date("m")-$month_offset;$year=date("Y");} $day = date("d",$limdate); if($month == 2 && $day > 28 && date("L")==0){$day=28;} elseif($month == 2 && $day > 28 && date("L")==1){$day=29;} elseif($month == 9 && $day > 30){$day=30;} $date = mktime(0,0,0,$month,$day,$year); $where = "time >= \"".date('Y-m-d',$date)."\""; // Date has been calculated as 2009-04-04 I also need to do this for the quartly and weekly scripts Code:
Weekly So where i have ... $periodstart = "2007-05-04 00:00:00" the final date i would need to get is 2009-04-27 Im sure there must be an easier way or im looking at it all wrong. Any help would be brill.
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
TSM, far far far too over complicated....
Drop to a MySQL console, and play with the following... Code:
$ndbconn = mysql_connect("localhost", "user", "password"); mysql_select_db("mysql"); $n_start_date = 1062521254; // Timestamp for 2003-09-02 11:47:34 taken from your DB // The query adds fourteen days to the given date $squery = "SELECT DATE_ADD(FROM_UNIXTIME($n_start_date), INTERVAL 14 DAY)"; $nresult = mysql_query($squery); $s_new_date = mysql_result($nresult, 0, 0); // Free the result mysql_free_result($nresult); // Disconnected mysql_close($ndbconn); echo "Your password will expire on $s_new_date"; ![]() |
#3 | |
The Sick Man
This is not for password usage, its for finding all records in a table where they are within the period to now. Ie i have a table of log entries that has a list of image downloads that the client has done, client X has a limit of 50 images per month/week/quarter/year but the start of each period has to be keyed to their periodstart date, ie startperiod is 2009-01-31, if user had yearly limits on then the start date would be 2008-01-31, if it was monthly it would be 2008-12-31, if it was weekly then it would be 2009-01-24.
Huh?
#5 | |
Code:
SELECT DATE_ADD(FROM_UNIXTIME($n_start_date), INTERVAL 1 YEAR); Code:
SELECT DATE_ADD(FROM_UNIXTIME($n_start_date), INTERVAL 1 MONTH); My original post, whilst a little obscure, was just really saying to use the MySQL Date_Add() function to calculate date differences. Take a look at the MySQL documentation for DATE_ADD() - it'll calculate everything much easier for you. EDIT: MySQL DATE_SUB() for subtractions. If you want, it could even be built into a nested statement and all executed within the DB to return the number of images per period, then use mysql_num_rows() to see if they're over the limit. Last edited by Baph; 07-05-09 at 09:18 PM. |
I will be honest with you, I wrote a java date class to give me date info such as start/end of week, month, year etc as system times for one of my projects.
package com.alstom.stats; /** * Insert the type's description here. * Creation date: (10/01/2003 11:18:37) * @author: Administrator */ import java.util.*; import java.text.*; public class GetMonthStartandEnd { /** * GetMonthStartandEnd constructor comment. */ public GetMonthStartandEnd() { super(); } /** * Insert the method's description here. * Creation date: (10/01/2003 11:26:25) * @return long * @param date long system time in seconds * */ public static long getEndofCurrentYear() { Date startDate = new Date(); Calendar calendar = new GregorianCalendar(); calendar.setTime(startDate); int month = calendar.get(calendar.MONTH); calendar.set(Calendar.MILLISECOND, 999); calendar.set(Calendar.SECOND, 59); calendar.set(Calendar.MINUTE, 59); calendar.set(Calendar.HOUR_OF_DAY, 23); calendar.set(Calendar.DATE, 31); calendar.set(Calendar.MONTH, Calendar.DECEMBER); long eoy = calendar.getTime().getTime(); return eoy; } /** * Insert the method's description here. * Creation date: (10/01/2003 11:26:25) * @return long * @param month int * @param year int */ public static long getEndofMonth(int month, int year) { Calendar calendar = new GregorianCalendar(); calendar.set(year,month-1,1,0,0); calendar.set(Calendar.MILLISECOND,0); calendar.set(Calendar.SECOND,0); calendar.set(Calendar.MINUTE,0); calendar.add(Calendar.MONTH,1); long som=calendar.getTime().getTime(); som--; return som; } public static long getEndofYear( int year) { Calendar calendar = new GregorianCalendar(); calendar.set(year,Calendar.DECEMBER,31,23,59); calendar.set(Calendar.MILLISECOND,999); calendar.set(Calendar.SECOND,59); long som=calendar.getTime().getTime(); return som; } public static long getStartofYear( int year) { Calendar calendar = new GregorianCalendar(); calendar.set(year,Calendar.JANUARY,1,0,50); calendar.set(Calendar.MILLISECOND,0); calendar.set(Calendar.SECOND,0); long som=calendar.getTime().getTime(); return som; } /** * Insert the method's description here. * Creation date: (10/01/2003 11:26:25) * @return long * @param month int * @param year int */ public static long getEndofMonth(long date) { Date startDate = new Date(date*1000); Calendar calendar = new GregorianCalendar(); calendar.setTime(startDate); calendar.set(Calendar.MILLISECOND,0); calendar.set(Calendar.SECOND,0); calendar.set(Calendar.MINUTE,0); calendar.set(Calendar.HOUR_OF_DAY,0); calendar.set(Calendar.DATE,1); calendar.add(Calendar.MONTH,1); long som=calendar.getTime().getTime(); som--; return som; } /** * Insert the method's description here. * Creation date: (10/01/2003 11:26:25) * @return long * @param date long system time in seconds * */ public static int getMonth(long date) { Date startDate = new Date(date*1000); Calendar calendar = new GregorianCalendar(); calendar.setTime(startDate); int month =calendar.get(calendar.MONTH); return month; } /** * Insert the method's description here. * Creation date: (10/01/2003 11:26:25) * @return long * @param date long system time in seconds * */ public static long getNow() { Date now = new Date(); Calendar calendar = new GregorianCalendar(); calendar.setTime(now); long som=calendar.getTime().getTime(); return som; } /** * Insert the method's description here. * Creation date: (10/01/2003 11:26:25) * @return long * @param date long system time in seconds * */ public static long getStartofCurrentFinYear() { Date startDate = new Date(); Calendar calendar = new GregorianCalendar(); calendar.setTime(startDate); int month = calendar.get(calendar.MONTH); calendar.set(Calendar.MILLISECOND, 0); calendar.set(Calendar.SECOND, 0); calendar.set(Calendar.MINUTE, 0); calendar.set(Calendar.HOUR_OF_DAY, 0); calendar.set(Calendar.DATE, 1); calendar.set(Calendar.MONTH, Calendar.APRIL); if (month < Calendar.APRIL) calendar.add(Calendar.YEAR, -1); long som = calendar.getTime().getTime(); return som; } /** * Insert the method's description here. * Creation date: (10/01/2003 11:26:25) * @return long * @param date long system time in seconds * */ public static long getStartofCurrentYear() { Date startDate = new Date(); Calendar calendar = new GregorianCalendar(); calendar.setTime(startDate); int month = calendar.get(calendar.MONTH); calendar.set(Calendar.MILLISECOND, 0); calendar.set(Calendar.SECOND, 0); calendar.set(Calendar.MINUTE, 0); calendar.set(Calendar.HOUR_OF_DAY, 0); calendar.set(Calendar.DATE, 1); calendar.set(Calendar.MONTH, Calendar.JANUARY); long som = calendar.getTime().getTime(); return som; } /** * Insert the method's description here. * Creation date: (10/01/2003 11:26:25) * @return long * @param date long system time in seconds * */ public static long getStartofFinYear(long date) { Date startDate = new Date(date*1000); int month = getMonth(date); Calendar calendar = new GregorianCalendar(); calendar.setTime(startDate); calendar.set(Calendar.MILLISECOND,0); calendar.set(Calendar.SECOND,0); calendar.set(Calendar.MINUTE,0); calendar.set(Calendar.HOUR_OF_DAY,0); calendar.set(Calendar.DATE,1); calendar.set(Calendar.MONTH,Calendar.APRIL); if (month < Calendar.APRIL) calendar.add(Calendar.YEAR, -1); long som=calendar.getTime().getTime(); return som; } /** * Insert the method's description here. * Creation date: (10/01/2003 11:26:25) * @return long * @param month int * @param year int */ public static long getStartofMonth(int month, int year) { Calendar calendar = new GregorianCalendar(); calendar.set(year,month-1,1,0,0); calendar.set(Calendar.MILLISECOND,0); calendar.set(Calendar.SECOND,0); calendar.set(Calendar.MINUTE,0); long som=calendar.getTime().getTime(); return som; } /** * Insert the method's description here. * Creation date: (10/01/2003 11:26:25) * @return long * @param date long system time in seconds * */ public static long getStartofMonth(long date) { Date startDate = new Date(date*1000); Calendar calendar = new GregorianCalendar(); calendar.setTime(startDate); calendar.set(Calendar.MILLISECOND,0); calendar.set(Calendar.SECOND,0); calendar.set(Calendar.MINUTE,0); calendar.set(Calendar.HOUR_OF_DAY,0); calendar.set(Calendar.DATE,1); long som=calendar.getTime().getTime(); return som; } /** * Starts the application. * @param args an array of command-line arguments */ public static void main(java.lang.String[] args) { // Insert code to start the application here. //expect 2 arguments month and year int month =-1, year=-1; if(args.length != 2){ System.out.println("Usage: GetMonthStartandEnd month year"); return; } try{ month = Integer.parseInt(args[0]); year = Integer.parseInt(args[1]); long start = getStartofMonth(month,year); long end = getEndofMonth(month,year); System.out.println("month start = "+ start + " : End = " + end); Date startDate = new Date(start); Date endDate = new Date(end); Calendar calendar = new GregorianCalendar(); calendar.setTime(startDate); DateFormat dt = DateFormat.getTimeInstance(); DateFormat df = DateFormat.getDateInstance(); System.out.println("month start = " +df .format(calendar.getTime()) + " " + dt .format(calendar.getTime())); calendar.setTime(endDate); System.out.println("month end = " +df.format(calendar.getTime()) + " " + dt .format(calendar.getTime())); end = getStartofDay(end/1000); endDate = new Date(end); calendar.setTime(endDate); System.out.println("start of last day = " +df.format(calendar.getTime()) + " " + dt .format(calendar.getTime())); end = getStartofDay(end/1000); endDate = new Date(end + 3600000); calendar.setTime(endDate); System.out.println("start of last day + 3600 = " +df.format(calendar.getTime()) + " " + dt .format(calendar.getTime())); } catch (NumberFormatException e){ e.printStackTrace(); } } /** * Insert the method's description here. * Creation date: (16/06/2005 13:41:22) * @return long * @param date long */ public static long getStartofDay(long date) { Date startDate = new Date(date*1000); Calendar calendar = new GregorianCalendar(); calendar.setTime(startDate); calendar.set(Calendar.MILLISECOND,0); calendar.set(Calendar.SECOND,0); calendar.set(Calendar.MINUTE,0); calendar.set(Calendar.HOUR_OF_DAY,0); long som=calendar.getTime().getTime(); return som; } } probably of no use, but I called these from a php system call where necessary to a wrapper class
Not Grumpy, opinionated. Last edited by timwilky; 07-05-09 at 09:19 PM. |
Tim, that doesn't really help much does it?
I was trying to demonstrate there are multiple ways of dealing with dates and being able to construct /calculate time.
PHP uses functions such as date_add, dateinterval etc to calculate dates/ arithmetic, offsets etc
Not Grumpy, opinionated. |
#9 |
The Sick Man
Code to work out the latest weekly date cycle given an initial date.
Smple but seems to work Code:
$date = strtotime("2008-05-5"); $date_now = strtotime("2009-05-7"); $date_now_epoch = date("U",$date_now); $date_epoch=date("U",$date); $new_epoch_date=0; $cur_epoch_date=$date_epoch; while($cur_epoch_date <= $date_now_epoch){ $new_epoch_date=$cur_epoch_date; $cur_epoch_date=$cur_epoch_date+(86400*7); } echo date("Y-m-d",$new_epoch_date);
#10 |
I still can't fathom why you don't let the DB do the work for you in this scenario.
![]() If all you're after is the number of records within a given date range from today (or any arbitary date), going backwards... Code:
<?php // subsitute these vars for whatever you need $table = "whatever"; $date_col = "date_created"; $interval = "WEEK"; // or MONTH or YEAR etc $int_count = 1; $cur_date = '08-05-09'; $query = "SELECT * FROM $table WHERE $date_col <= $cur_date AND $date_col >= DATE_SUB($cur_date, INTERVAL $int_count $interval) ORDER BY $date_col DESC;" $result = mysql_query($query) or die(mysql_error()); // you now have a MySQL result resource containing all records from $table within the last week, ordered by the date column (newest first). ?> |
Any ASP coders out there | timwilky | Idle Banter | 3 | 19-03-08 12:26 AM |
Windows script help | tricky | Idle Banter | 2 | 29-03-07 11:55 AM |
NEEDED: Good PHP coders | TSM | Idle Banter | 0 | 02-10-06 01:55 PM |
For those in who know MySQL | tomjones2 | Idle Banter | 3 | 28-04-06 06:05 PM |
Script help | sharriso74 | Idle Banter | 13 | 03-02-06 03:53 PM |
