Old 08-05-09, 10:08 AM   #1
SUPERSTARDJ01
Default Valve clearances - how do you know?
How do you know when the tappetts need servicing apart from the service intervals?
Old 08-05-09, 10:18 AM   #2
Holdup
Default Re: Tappetts
They tap
Old 08-05-09, 10:20 AM   #3
jimmy__riddle
as long as they are done at correct service intervals i wouldnt have thought they would need doing. quite often they can be within tolerance when checked at service intervals. if theres any doubt though its worth checking, or if they are noisey.
Old 08-05-09, 11:08 AM   #4
ThEGr33k
Under "normal" conditions I dont think you will notice really as the bike will probably lose power over time so you'll think its normal.
Why do you ask?
They tap
Well... not noticeably unless they are ridiculously out tbh.
Old 08-05-09, 11:15 AM   #5
jimmy__riddle
on another note, if the clearance gets smaller, do they make much of a noise?
Old 08-05-09, 01:31 PM   #6
SUPERSTARDJ01
Well the reason I ask is because in the morning the bike sounds fine but when I get to work around 8 miles away it starts to sound like to pieces of metal clanging, well mybe not that bad but you get the idea, sounds a bit like a small tractor.
It had a service less than 1000 miles ago.
Old 08-05-09, 01:38 PM   #7
ThEGr33k
As long as it has oil then it should be fine. The SV does have big internals so does make some noise. Im sure itll be nothing.
Old 08-05-09, 01:39 PM   #8
jimmy__riddle
Were the clearances checked at the service?
Old 08-05-09, 01:42 PM   #9
SUPERSTARDJ01
Hi,
I don't think so I bought it from a garage with 14300 miles on it so close to the 15000 miles tappet service, I think they did a full service but not tappets.
Old 08-05-09, 01:43 PM   #10
ThEGr33k
Originally Posted by SUPERSTARDJ01 View Post
Hi,
Did they not at least check the clearance?
Valve Clearances pmapp SV Talk, Tuning & Tweaking 6 23-01-09 01:28 PM
Valve clearances - K3 Lozzo SV Talk, Tuning & Tweaking 1 24-07-08 09:24 AM
Valve Clearances DanAbnormal Bikes - Talk & Issues 31 07-02-08 06:22 PM
Doing the valve clearances... instigator SV Talk, Tuning & Tweaking 7 16-10-06 10:08 PM
Valve Clearances HELP TSM SV Talk, Tuning & Tweaking 25 05-04-06 09:58 AM
