Old 09-05-09, 12:06 AM   #1
XmisterIS
Default How to lighten the clutch?
Hi all,
I have just got my naked SV, and I like it (obviously!) but the only thing I don't like is that the spring-back on the clutch lever is so strong it makes my hand ache after about 40 mins or so!
I would like to reduce the spring-back force just a little.
How can I do that?
Old 09-05-09, 12:17 AM   #2
Jamiebridges123
Default Re: How to "loosen" the clutch lever?
I don't believe you can? The clutch on an SV is really light anyway, IMO.
Old 09-05-09, 12:20 AM   #3
ophic
ophic's Avatar
I experienced a similar problem when I first got my SV 5 years ago. I didn't find a solution, i'm afraid. However, after a few weeks of riding the muscles in my hand must have improved as it stopped bothering me!
There are things you can do though. Make sure the lever is angled right for your hand - you can rotate the lever mount round the handlebar until its comfortable. Also if you have small hands you can adjust the clutch so that it bites somewhere manageable, rather than too far out. You do have to be careful doing this that the clutch is still fully disengaged when the lever is pulled all the way in.
Silver SV650SK3, Fuel exhaust
Old 09-05-09, 08:39 AM   #4
Bluefish
what tothers said,or eat three shredded wheat and MAN UP.
Old 09-05-09, 09:18 AM   #5
pmapp
pmapp's Avatar
Also make sure the cable and all the tiwddly bits behind the sprocket cover are well oiled and lubed.
Old 09-05-09, 02:27 PM   #6
XmisterIS
Default Re: How to lighten the clutch?
Thanks! I will get used to it!
bluefishman ... I am "manned up", I am a rock climber! (strong hands anyway!) I'd just prefer it if the clutch was a little more dainty and feminine, to match my pink leathers and my "hello kitty" helmet ....
Old 09-05-09, 02:37 PM   #7
Bluefish
lol
Old 09-05-09, 02:39 PM   #8
ThEGr33k
This is mad... The SV's clutch is so light that it takes the micky. I had a play with my old one (mate has it) and it felt broke it was so easy. Seems my Falco's is super heavy ha ha
Go to the Gym is my advice, climbing should mean you'd be ok though id have thought... count it as extra workout
Welcome to the forums!
Old 09-05-09, 03:03 PM   #9
XmisterIS
Hmmm .. perhaps there is something up with my clutch then! Might need a bit of lube - it is a lot stiffer than either my old 125 or the CB500 that I rode with the instructor.
I might take it to my local suki dealer and ask them to cop a feel and see if it is ok (the clutch that is!).
Gear changes are fine though, I find the bite is very deep and forgiving - not like my 125, which was very on/off.
Old 09-05-09, 03:40 PM   #10
ThEGr33k
Where are you? If your reasonably local I don't mind trying to help...
Best quick fix will be to spray some WD 40 in there.
Yet another digital speed camera to lighten my wallet w302977 SELKENT 0 15-02-08 08:26 PM
Clutch Problem? Cutting off when releasing clutch in first gear! puthsardarade SV Talk, Tuning & Tweaking 15 09-01-08 09:42 PM
hey new clutch advice Kyoto Clutch srxaus SV Talk, Tuning & Tweaking 3 14-08-07 04:25 PM
Clear clutch covers to see the clutch spin while running. TLRMAN SV Talk, Tuning & Tweaking 13 01-11-04 02:18 PM
