Old 10-05-09, 10:34 PM   #1
BournemouthBen
Default Swapping stubby exhaust between bikes
Hello,
My old man has a carbon end can from his Bandit 1200 lying around the garage, and I'd quite like to use it when i get a bike
He removed it and replaced it about a year ago. Its in perfect working order and its been a bit trimmed.
I'd like to know whether it would fit onto a K3 pointy with appropriate pipping and stuff...
to be honest I don't have a clue what I would have to do to fit it! Its got 4 holes in its 'engine end' one big 'un for the fumes, and 3 little threaded ones, to attach onto the rest of the exhaust.
Is this fitting area fairly universal or specific to Bandits?
i drew a picture coz i couldn't be arsed to take a pic!
thankyouuu!
Ben.
Old 10-05-09, 10:39 PM   #2
hovis
Default Re: Swapping stubby exhaust between bikes
that looks simerler to my fireblade can.
you couldmake it fit, but would need to fit a link pipe from the bandit to your pipe, which IMO is a lot of work, when you can just get the right can to fit
Old 10-05-09, 11:13 PM   #3
Jamiebridges123
I'm guessing that's where it bolts onto the pipe? If you can find the right link pipe then it should fit but may be a hassle.
Old 11-05-09, 12:19 AM   #4
You'll need a custom link pipe for that, or a normal SV link pipe and an adaptor.
Old 11-05-09, 04:51 AM   #5
Mr_Chin
Mr_Chin's Avatar
IIRC, Banditmania sell a slip on to bolt on exhaust adaptor - £50 I think. HTH
- SK4.SV650.2004.YC2
- D3N15
Mr_Chin is offline   Reply With Quote
Old 11-05-09, 07:35 AM   #6
BournemouthBen
found this...
Bolt on adapter
i guess this would bolt onto the bottom of the can and i would then need to find appropriate link pipes...only...which ones and how?!
Old 11-05-09, 07:40 AM   #7
Mr_Chin
Mr_Chin's Avatar
Originally Posted by BournemouthBen View Post
found this...
Bolt on adapter
Is there not a link pipe or pipe on the bike already?
If there is, then this would slip on to it with an exhaust clamp, then bolt the end can on.
Job done.
Chin
- D3N15
Old 11-05-09, 07:48 AM   #8
BournemouthBen
ooooh Ok. ill look into it.
Stubby exhaust advice. Sio_08 SV Talk, Tuning & Tweaking 10 27-03-09 10:08 PM
Stubby exhaust Alpinestarhero Stuff Wanted 1 13-12-08 05:40 PM
Stubby Exhaust Larry SV Talk, Tuning & Tweaking 3 19-01-08 07:26 PM
making a stubby exhaust silent SV Talk, Tuning & Tweaking 21 10-02-06 05:40 PM
Swapping the exhaust mysteryjimbo SV Talk, Tuning & Tweaking 2 06-10-04 10:48 PM
