Old 11-05-09, 09:44 PM   #1
Holdup
Default Removing flywheel
Got the generator cover + generator off the FZR but cant get the flywheel off, removed the bolt but now it wont budge! any techniques special tools i should be using?
Thanks
Old 11-05-09, 09:46 PM   #2
Default Re: Removing flywheel
A flywheel puller would be a fine start.
Pics of the flywheel area and it may become apparent what sort of puller is needed.
Old 11-05-09, 09:48 PM   #3
Jamiebridges123
Not directly helping but have you gotten one of those manufacturer book things?
http://motorbikemanuals.blogspot.com...ce-manual.html
Here for yours mate.
Old 11-05-09, 09:49 PM   #4
BanditPat
Fly wheel puller as YC said. I didnt have one when I had to replace mine a month or two ago I used a brake hub puller but it still needed a fair bit of persuasion and 2 pepole to take it off. eventually the shock from a hammer knocking the handle on the puller was enough to loosen it.
Old 11-05-09, 09:52 PM   #5
BanditPat
is that anything like it?
Old 11-05-09, 09:54 PM   #6
Need to know what's under that bolt. If there is a thread inside (not the bolt thread in the crank nose, a thread in the flywheel) then you need a bolt to fit it. That will press the crank out of the rotor.
Old 11-05-09, 10:00 PM   #7
Holdup
Well its a flywheel its similar but dont look like that one
Yea there is a bigger thread in the actual flywheel but cannot find a bolt big enough any where in my workshop, my Dad was on about pulling my rear wheel spindle out of my sv to see if that was big enough, will ask if work have a flywheel remover tool tomorrow.
Old 11-05-09, 10:01 PM   #8
BanditPat
http://www.fzrarchives.com/fzr400/FZ...ng%20flywheel?
Old 11-05-09, 10:01 PM   #9
Depends on the size. Some bikes happen to have a swingarm spindle that's right. SV is M20 fine pitch... picked one up locally for £2.
Old 11-05-09, 10:04 PM   #10
Originally Posted by http://www.fzrarchives.com/fzr400/FZR400%20Frequently%20Asked%20Questions.html#How%2 0do%20I%20remove%20the%20*&$#ing%20flywheel?
the rear axle will also serve this purpose,
Try it.
Get some diesel on hand. Don't be afraid to screw it in as tight as you dare and leave it for a couple of days and see if it will "creep" off
SV flywheel rotor lightening Tirofog SV Talk, Tuning & Tweaking 13 04-02-09 05:05 PM
Flywheel Removal Tool defiant Stuff Wanted 10 06-12-08 04:24 PM
Flywheel removal tool yorkie_chris Stuff Wanted 9 19-04-08 12:17 PM
Flywheel thread size gc350 SV Talk, Tuning & Tweaking 2 28-06-07 07:37 PM
Flywheel Puller Tool TSM SV Talk, Tuning & Tweaking 1 02-01-06 04:34 PM
