in the last 2 days ive been having a "spirited" ride into work. on 2 occasions going from first to second at about 9k its jumped out of gear into neutural. however no light just no gears.
im thinking the chain is on the top limit (slackest) would this cause it? its fine otherwise...... however i also had a thing the other day when i stopped it with the side stand. when i restarted it it stuggled like it had hit hydraulic lock in the cylinder. it didnt fire but when i tried again all was fine, and its been fine today. again any thoughts? |
Mine on used to do this when I wasnt very positive with the lever. Usually when I was concentrating on some spirited riding.
Maybe stopping it with the side stand causes it to flood with fuel. Although this wouldnt lock the engine it might have stopped the plugs firing to help it turn over the first couple of times. Last edited by ivantate; 12-05-09 at 11:55 AM. |
#3 | |
Mine used to do this between 5/6th gears on the motorway...
Today it just wouldn't select any gears at all... I'd have someone look at it so that you possibly don't end up like me and completely screw*d on the side of the road... |
Check the oil, check the lever pivot is OK. Make sure you are putting it all the way into gear.
mine done that yesterday. is on a 58 plate |
reg plate, so it aint that old and havin a bit of trouble
#9 |
What do you mean wouldn't select any? Wouldn't go into first at a standstill?
#10 |
Mines popped out of 6/5 on the motorway in the past, the revs just suddenly go through the roof. Never had any problems though really, although not really sure how it finds these false neutrals
Bike keeps jumping out of 2nd gear. | jimmy-james | Bikes - Talk & Issues | 23 | 25-04-09 11:13 PM |
red light jumping cyclist.... | Spiderman | Idle Banter | 40 | 15-07-08 04:40 PM |
jumping out of 2nd :-( | The Laughing Assassin | SV Talk, Tuning & Tweaking | 10 | 24-06-08 12:27 PM |
Cliff jumping! | ClemsonSV | Idle Banter | 7 | 25-07-07 02:23 PM |
Nutty Tart jumping out a plane - who will pay to help this? | Anonymous | Idle Banter | 86 | 05-08-06 06:10 PM |
