Old 15-05-09, 11:12 AM   #1
branny
Default RH rear panel removal
i am trying to get at my Reg/Rec and need to remove the rear RH panel.
how in the world do i detach it from the back panel? it is stuck at the very rear where the brake light is.
I have removed it from the turrt that the handle connects to, just stuck!
any tips?
Old 15-05-09, 11:14 AM   #2
chasey
Default Re: RH rear panel removal
Is there a screw underneath that sits in the corner near the number plate hanger?
Old 15-05-09, 11:20 AM   #3
vardypeeps
If it's a curvy you might aswell take the whole rear fairing off in one piece just don't flex it too far!
Old 15-05-09, 11:22 AM   #4
branny
yes, it's a curvy. maybe i will take the whole thing off...
i didn't see any screws, it just seemed to be entangled with the black panel at the rear.
Old 15-05-09, 11:25 AM   #5
branny
just looking at the manual and it does show a screw underneath. i will go back and try again!
Old 15-05-09, 11:26 AM   #6
vardypeeps
If you get a little torch or some light in there and look just behind the 'top' of the undertray there are two last screws on either side.
You also need to pull the fairing up off the screw mounts after taking the plugs out of the bugs if you get me?
Hard one to explain.
Do you have a Haynes handy for it?
Old 15-05-09, 11:29 AM   #7
BoltonSte
Assuming you've removed the ones behind your **** when you sit on the bike (holding both halves together) and the nuts under the subframe, and screws through the rubber mounts above. Then there are 2 screws up at the back near the light. You get to them from underneath, right in the corner where the original mudguard bends down.
Ste
Had an SV or three.
Street triple R - gone but not forgotten.
Now trying the lunacy that is KTM with a Superduke GT. for the pillion capability of course.
BoltonSte is offline   Reply With Quote
Old 15-05-09, 11:30 AM   #8
BoltonSte
Damit, beaten to it, must learn to type faster. If you are still stuck, then a post on the Pennine Massive may get someone you can bob over to you.
Had an SV or three.
Old 15-05-09, 11:45 AM   #9
branny
got the panel off.
cheers guys, that was easy!
Old 15-05-09, 02:08 PM   #10
johnnyrod
johnnyrod's Avatar
Easy? I must have been doing something wrong the time I had to!
sv650 55plate l/h rear panel,tank,etc cowboy racing Stuff Wanted 1 10-05-09 05:36 PM
SV650s Black L/H Rear Seat Panel chrishallett21 Stuff Wanted 2 26-01-08 05:31 PM
Rear Left side fairing panel sprocket Stuff Wanted 1 22-09-06 12:28 PM
Brand new rear RHS panel weemo For Sale - SV's and SV related items 0 18-07-06 02:58 PM
l/h rear panel 2000 curvy sv650 BIKER-DENE Stuff Wanted 0 04-03-06 11:27 PM
