Old 16-05-09, 10:54 PM   #1
parkinmj
Default Pointy Engine parts
OK guys I have split an engine for parts.
Everything available is listed below
postage is seperate.
3 x con-rods £10 each
2 x clutch baskets plates and springs £35 each ( one basket, plate set and spring set )
2 x starter motors £25 each
2 x thermostat and valve £10 each
2 x Oil Pressure relief valves £10 each
2 x oil pressure switches £5 each
2 x Gear position sensors £10 each
2 x cam chain adjusters (1 rear 1 front) £30 for both
2 x fly wheels/gennies £25 each (includes windings and ignition timing pick up )
2 x starter motor clutches and gears £20 each (one clutch and one gear)
2 x set of cam chains, gears and guides £25 each (front and rear per set)
2 x gear selector rods (the ones which run through the engine) £5 each
2 x battery to engine earth wires £2.50 each
2 x oil pump drive gears £2.50 each
2 x water pump drive gears (the metal ones on end of crank) £2 each
2 x primary drive gears £5 each
2 x idle reduction gears + shafts £7.50 each (one shaft and gear)
1 x crank £80
1 x gear box £100 (includes selector forks)
2 x selector drum £10
1 x selector fork set £30
1 x rear cylinder+ matched piston £40
1 x front cylinder +matched piston £40
1 x front cylinder head(will not split any further Cams included) £65
1 x rear cylinder head (will not split any further Cams included) £65
1 x 33bhp restricted ECU £75
1 x clutch cover £20
1 x water pump £15
1 x scratched left side cover £5
1 x left side cover (no scratches) £20
1 x piston £5
1 x 16t front steel sprocket (used but lots of life left) £2
1 x rear exhaust manifold/ down pipe £5
1 x first gear pinion £3
Any questions feel free to ask
Everything is ready for immediate dispatch.
And pictures are availible just ask
All the best
MJP
Old 16-05-09, 10:59 PM   #2
drag
Default Re: Pointy Engine parts
Cam chain adjusters right here !!
Wait ... is it a K3 engine your breaking or a K5 ?
If it's a K3 i'll take the Cam tentioners/adjusters if it's a K5 i'd like these parts
25381-19F10
25350-35F00
25355-35F01
Old 16-05-09, 11:33 PM   #3
parkinmj
cam chain adjusters are off a k5.
Old 17-05-09, 09:21 AM   #4
Spikenipple
Spikenipple's Avatar
Do you have a pair of crank cases please?
Had: K7 SV650S in Candy Sonoma Red
Now: MT-09
My old SV
South & West Surfer
Spikenipple is offline   Reply With Quote
Old 17-05-09, 11:39 AM   #5
parkinmj
sorry they sold before the week end.
all the best
MJP
Old 07-06-09, 04:30 PM   #6
green1
hi do you still have front&rear cylinder heads for sale
Old 08-06-09, 11:11 PM   #7
parkinmj
Hi mate
sorry you just missed them they went on ebay last night.
All the best
MJP
Old 12-06-09, 10:14 PM   #8
parkinmj
Ok guys im moving soon and dont need any of this but being a student and all that i cant just let it go for free so im opening everything up for offers. or if someone wants it all £100 for the lot.
1 x con-rod
2 x con-rods
2 x clutch baskets plates and springs ( one basket, plate set and spring set )
2 x starter motors
2 x fly wheels/gennies (includes windings and ignition timing pick up )
1 x starter motor clutch and gear
2 x set of cam chains, gears and guides (front and rear per set)
1 x crank
1 x gear box
2 x selector drum
1 x clutch cover
1 x water pump
1 x piston
http://thegallerycuttingcrew.co.uk/EngineParts.html
http://thegallerycuttingcrew.co.uk/EngineParts2.html
http://thegallerycuttingcrew.co.uk/EngineParts3.html
http://thegallerycuttingcrew.co.uk/EngineParts4.html
http://thegallerycuttingcrew.co.uk/EngineParts5.html
http://thegallerycuttingcrew.co.uk/EngineParts6.html
all the best
Michael
Old 13-06-09, 10:24 PM   #9
parkinmj
Also got a haynes manual - used- oil and grease stains but still readable with all pages intact and none missing say £5 and free p+p
Aswell as a set of brand new Rear pads for a K5 not sure if they will fit other years but they are EBC's HH pads, new "c" formula Superbike,Streetsport and race formula pads. Still in there original packaging say £12 and free p+p
All the best
MJP
Old 14-06-09, 03:27 PM   #10
Seggons
Out of interest how much would you let the clutch baskets plates and springs go for?
Pointy engine parts markmoto For Sale - SV's and SV related items 26 13-10-08 09:52 AM
SV Engine Parts - 05 Bike Hooligan For Sale - SV's and SV related items 3 15-08-08 01:43 PM
Crash.NET - Victory confidence, engine parts boost Suzuki. NewsBot News 0 29-05-07 03:30 PM
K1 + K2 engine parts for sale. Daimo For Sale - SV's and SV related items 1 10-02-07 09:02 PM
