Old 19-05-09, 01:10 PM   #1
benjyman
Default Fuse keeps blowing
Was riding to uni the other day and suddenly RPM, speedo, indicators, neutral light etc stopped working. Got home, changed fuse, all fine. Then yesterday same thing happened. Have made a few changes recently. New speedo drive as old one was nackered, and also my back right indicator wasn't working for some reason so i had to wiggle the bulb about a bit.
Anyone had this problem at all? Might take the indicator bulb out before changing the fuse and see if that helps.
Old 19-05-09, 01:11 PM   #2
Jamiebridges123
Default Re: Fuse keeps blowing
Change the bulb/indicators and give all the connections a spraying of WD40, then check the reg/rec if it keeps blowing things.
Old 19-05-09, 01:13 PM   #3
gettin2dizzy
Sounds like it's shorting. You played with any of the bike recently?
Old 19-05-09, 01:43 PM   #4
benjyman
See first post - i've had a fiddle with one of my indies, and changed the speedo drive.
Another thing - It was raining both times, although i haven't ridden it when not raining to be fair
Old 19-05-09, 01:45 PM   #5
gettin2dizzy
It'll be the indies then. I did the same
Old 21-05-09, 10:20 PM   #6
benjyman
GRRRRRRRRRRRRRRR
I've now realised that my headlight, both dipped and full beam, has ceased to work. Can't think how the full beam fuse could have gone as i've not used it recently. I'll check the fuses tomorrow, but does this sound like a Reg/Rec problem?
I haven't tried to start it again since i realised so i hope i'm able to.
Old 22-05-09, 11:06 AM   #7
thefallenangel
could well be. Check.
Old 22-05-09, 11:11 AM   #8
what bike is it?
If its a faired curvy, have a peep at the red wire that runs from the big plastic connector block on the left side(sitting on bike) make sure its nice and clean and has a good contact.
I had a recent spate of blowing fuses, and on close inspection, when given a technical wiggle it made all the clock needles bounce everywhere. Cleaned up, and connected directly to itself, stopped it immediately. The terminals were then closed up slightly and put back in the relevant bit on the plastic connector. Never had an issue since
Its worth a shot....if its a faired curvy
Old 03-06-09, 11:53 AM   #9
benjyman
It turns out the headlights are just a bit temperamental. It started working again without me having done anything. Any ideas what that could be? I've heard something about the starter button?
The fuse hadn't gone for ages, and i'd taken the back right indicator bulb out so i thought it must have been that causing it, but it went again yesterday. Where should i be looking for dodgy connections/wiring? Are there any common places?
It's a naked curvy.
Old 03-06-09, 11:57 AM   #10
plowsie
Ahh see when I did the same I managed to accidently short the indi wire out on the headlight, so with indi on trying to get it to flash, I had my headlight flashing Blows a few fuses...
fuse keeps blowing bobm SV Talk, Tuning & Tweaking 5 23-10-08 07:57 AM
Ignition Fuse blowing Frogman SV Talk, Tuning & Tweaking 7 16-04-07 05:57 PM
ignition fuse keeps blowing any ideas adey SV Talk, Tuning & Tweaking 6 06-06-06 04:22 PM
Main fuse keeps blowing JMCHITTOCK SV Talk, Tuning & Tweaking 7 09-09-05 11:17 AM
HELP...keep blowing a fuse jessie SV Talk, Tuning & Tweaking 5 24-03-05 10:01 PM
