Old 22-05-09, 07:54 PM   #1
matt_rufus
Default headlight problem
hi
my headlight doesn't work either beam, my little side light works,
i've changed the bulb checked the fuses, boycotted the plug checked the handlebar switch conections and even tried runing the light direct from the fuse box, nothin!! now i'm completly stuck!
Old 22-05-09, 07:55 PM   #2
simesb
Default Re: headlight problem
Checked the earth on the multiplug at the back of the bulb has continuity?
Pointy or curvy?
Old 22-05-09, 10:20 PM   #3
matt_rufus
it a curvey
Old 23-05-09, 03:09 PM   #4
It's just a case of seeing where power is getting to.
You got wiring diagram? Follow path of power see where it stops.
Old 24-05-09, 11:44 AM   #5
matt_rufus
did some fiddling tried different wires looked at both switchgears it now works dont know how but who cares it is working
Old 25-05-09, 09:18 AM   #6
BigFootIsBlurry
BigFootIsBlurry's Avatar
You'll care when it all goes dark when riding at night. I would still have a dig about if I was you. Pleased you got it working though.
Ain't no sunshine when she's gone...
2000 curvy, yellow and naked. Gone but not forgotten.
BigFootIsBlurry is offline   Reply With Quote
Headlight problem. svdemon SV Talk, Tuning & Tweaking 4 07-08-07 09:17 PM
Battery problem / Alternator problem? localhost SV Talk, Tuning & Tweaking 4 07-07-06 09:32 AM
Single headlight to dual headlight swap Jase22 Bikes - Talk & Issues 2 23-06-06 11:19 AM
Headlight Mounting bracket, headlight vincerhodes Stuff Wanted 1 10-05-06 07:12 PM
