Old 23-05-09, 04:24 PM   #1
DaveP
Default scotoiler help please
Where is the point on the engine that i fix the pipe from my scotoiler on the k3?
and which is the best position to fix it to the swing arm? in your opinion.
cheers
dave
Old 23-05-09, 05:06 PM   #2
mattb200
Default Re: scotoiler help please
thinking about getting one of these myself and i have a K3 too......
IIRC one of the throttle bodies has 2 connections and the other only one - so connect to the throttle body with 2.
As far as fitting goes I have no idea. I have been looking on the scottolier website at their fitting suggestions - it does say under the seat but I am not sure it will fit??
try looking here: http://www.scottoiler.co.uk/support_...ion-guides.asp
Old 23-05-09, 06:04 PM   #3
http://forums.sv650.org/showthread.php?t=108978
Old 23-05-09, 06:17 PM   #4
metalmonkey
I have one on my bike.....I have fitted the actual unit under the pillion seat, its held in place with a cable tie. The bets place is down inside of fairing, however I can't get mine there casue of the alarm.
I have cable tied the injector to swing arm, the tube runs underneath it. I put black electrical tape around the swing to prevent it rubbing. Mine seems to be working well. I don't go through alot of oil. My chain has done 12 000 miles and has needed little adjustment.
Old 25-05-09, 10:31 AM   #5
I get approx 1000 miles per fill.
Scotoiler? skapegoat SV Talk, Tuning & Tweaking 5 05-02-09 12:54 PM
Scotoiler 365.... Andy Jeffries SV Talk, Tuning & Tweaking 17 06-11-07 12:29 PM
Scotoiler Slapstick Stuff Wanted 8 21-02-07 09:59 AM
scotoiler cuffy Stuff Wanted 3 14-07-06 01:44 PM
scotoiler russg SV Talk, Tuning & Tweaking 12 11-03-06 11:37 PM
