Old 25-05-09, 08:31 PM   #1
davepreston
Question how to hold the front end while removing forks
tried using a jack ,bike was swinging all over the place and im doing two bikes so im not laying out for two proper stands ,forks being swapped betwen bikes at same time
Old 25-05-09, 08:33 PM   #2
BBadger
Default Re: how to hold the front end while removing forks
Saw some one on here use a ladder( over the bike ) and a heavy duty ratchet strap through the frame under the tank.
Seemed to work alright.
Old 25-05-09, 08:33 PM   #3
mine stood on house bricks and a piece of wood but a rope round the head stock up to a garage beam might help to keep it stable.
Old 25-05-09, 08:35 PM   #4
davepreston
no garage
Old 25-05-09, 08:37 PM   #5
well i actualy didnt use the rope idea but it stood just fine on house bricks and wood.
Old 25-05-09, 08:40 PM   #6
timwilky
timwilky's Avatar
are they ridable?
come up here and sling it from my engine lift. Or I can shove it in the back of the car a lend it to you
Not Grumpy, opinionated.
Old 25-05-09, 08:41 PM   #7
Jack under the sump with a rag on it, lean it over.
3 points of contact; sidestand, jack, back wheel.
Stable enough, but crack all the bolts loose before you jack it up.
Old 25-05-09, 08:45 PM   #8
davepreston
are they ridable?
favor taken off that good man
cheers wilky lad but no they are not ride able so would have do annoy you to drop it off and probably use your knowledge in the spanner wrenching department
Old 25-05-09, 08:49 PM   #9
Dave20046
Dave20046's Avatar
I used a jack. On other bikes I've used a ladder and rope.
Old 25-05-09, 08:53 PM   #10
timwilky
timwilky's Avatar
pm me your number dave and I will arrange to pop over
Removing Front Indicators From a Pointy COLZO SV Talk, Tuning & Tweaking 4 24-01-09 12:33 AM
Removing cover to front sprocket twopots SV Talk, Tuning & Tweaking 9 19-01-09 01:49 PM
removing front sprocket pointy SV Talk, Tuning & Tweaking 3 31-05-08 05:44 PM
What's the best stand to support the bike, while removing forks DarrenSV650S SV Talk, Tuning & Tweaking 23 30-10-07 05:51 PM
Metzeler Z6 Front? (Hard To Get Hold Of) Sledgehammer SV Talk, Tuning & Tweaking 2 03-05-05 12:29 PM
