Old 26-05-09, 11:19 AM   #1
Corf
Default rear hugger question
hey
i fitted a pyramid hugger few weeks back and couldn't get it to sit straight. on the chain side its got plenty of room but on the other its only about 4 mm away from tire. i have tried to get it to sit right but it won't so my questions is - if i put a wedge of something between tire and hugger then got a hair dryer on the go to try and warm it to form - would that work?
cheers
Old 26-05-09, 11:36 AM   #2
warrenhewitt10
Default Re: rear hugger question
yeh both mine and 2 of my mates have sv650s with huggers and not one of them sits completely straight...... i think it must just be the way they are made
Old 26-05-09, 11:39 AM   #3
Corf
cheers
will get the dryer on it tonight.
Old 26-05-09, 11:39 AM   #4
Woz
Mine has a metal bracket on the brake side. I found that bending that a little helped with the spacing.
Old 26-05-09, 01:09 PM   #5
BBadger
Metal bracket which holds the break line in. its ment to mout to that so just move it furuthur towards the engine and it should straighten things out abit.
mines still not perfect, but so close.
Old 26-05-09, 01:41 PM   #6
2hys
mine bolts down on that brake line holder, i just used washers two lift it up away from the tyre, i wouldnt advise warming it up you may end up distorting it!!
Old 26-05-09, 01:48 PM   #7
Dave20046
Dave20046's Avatar
ditto
Don't worry about it being 'only 4 mm' away. mine looks even less than that IIRC and it's been fine for the past 5k miles.
Old 26-05-09, 02:36 PM   #8
Corf
cheers guys
may have a blast at moving the bracket forward then. was faffing for over 30 mins to try and get it right and in the end gave up in a huff.
Old 26-05-09, 02:42 PM   #9
Dave20046
Dave20046's Avatar
Originally Posted by Corf View Post
cheers guys
for the best I usually get in a huff then try and angrily persue then brake it. doh
Old 26-05-09, 02:53 PM   #10
BBadger
Cant remember if i did this or thought about it.
Small file and elongate the holes that go on the chain side so you can even things out abit more (dont think it would harm the structure to much, or would it? ). i definatly however got rid of those crappy plastic washers and replaced with nice stainless steal for about 50p.
black rear hugger or carbon rear hugger? chipnix SV Talk, Tuning & Tweaking 9 05-07-07 04:05 PM
Rear Hugger Question!!!!! Much Urgency! :o( Kinvig SV Talk, Tuning & Tweaking 4 14-07-06 07:54 AM
Hugger Question 1world2wheels SV Talk, Tuning & Tweaking 4 09-06-06 10:23 PM
Hugger Fitted - rear brake hose question. Mr P SV Talk, Tuning & Tweaking 6 29-06-05 07:44 AM
To hugger or not to hugger? That is the question!! CatfordSV SV Talk, Tuning & Tweaking 5 27-03-05 10:44 AM
