Old 28-05-09, 08:18 AM   #1
drag
Default Brake disc rivets
Random questions of the day, on your average brake rotar you have 8 buttons, on most of the OEM kit i've seen they do.
Point in case
However some after market rotars have 9 of these buttons.
both are detailed as being for the old GSXR series bikes, bit i cant for the life of me find any info relating to size or diameter etc
Enlighten me might org ...
Old 28-05-09, 08:23 AM   #2
Default Re: Front rotar buttons.
GSXR 1996 > 03 use those flat 320mm rotors. Newer stuff uses smaller discs, latest is using like 300mm.
Rivet number makes no difference.
Old 28-05-09, 10:35 AM   #3
drag
Just cant figure out if they are closer together or if they are any size diff over all, those two above are from the same year...
Old 28-05-09, 12:07 PM   #4
vardypeeps
Originally Posted by sarannan View Post
Find Chrome Front Rotor Bolts Button Head Torx in the eBay Motors , Parts Accessories , Motorcycle Parts , American , Brakes Suspension category on eBay ...
growth hormone
tumescent liposuction
Someone delete this guy off the forum.
On looking at those pics the wavys look like the rivets are closer.
End of the day if they marked them for the wrong bike and send them to you send them back.
Old 28-05-09, 12:16 PM   #5
muffles
310mm I think, pretty sure that's what my 750 has.
Old 28-05-09, 01:05 PM   #6
drag
Default Re: Brake disc rivets
Said waveys are off a K1/K2 or so they say, i was just curious more so than anything.
Old 28-05-09, 02:26 PM   #7
My mistake it was 03-04 1000 or 04-05 750 used 300mm
Old 28-05-09, 02:32 PM   #8
ThEGr33k
New EBC have 6 button! They use some new Tech though to allow it. http://www.youtube.com/watch?v=9ZxNSI4VVOY
While we are on the subject little Q (as a side note). My Buttons could do with changing I think. They are looking a little worse for wear having gone through 2 winters.
Anyone know where I might be able to get them done?
My disc's http://www.youtube.com/watch?v=ix0PFcDC2nU
320mm 9 button Big Un's
Old 28-05-09, 03:00 PM   #9
drag
No problem there chris, i have the K1 forks and a K2 wheel now , on a side note also, how did the M4 fit go ? any change of a video ?
Old 28-05-09, 03:04 PM   #10
Fit fine. Only problem was I cut the exhaust hanger off the stock pillion peg when I had high level... so fitted some daytona 955i pillion pegs I had kicking about and bolted can onto that. Means it points up and inward, a bit similar to TLR style.
Could do a video I suppose but it doesn't sound anything special, just like a slip on can but louder.
Noise and very hot brake disc. BBadger Bikes - Talk & Issues 11 12-04-09 06:02 PM
Disc Rotor Loose At Rivets!!!!(Again) NedSVS SV Talk, Tuning & Tweaking 1 12-03-07 11:26 PM
Disc Rotor Loose At Rivets!!!! NedSVS Tyres 4 12-03-07 10:34 PM
Brake Disc thickness andyb SV Talk, Tuning & Tweaking 7 14-11-06 10:49 AM
A Tip to Get Rid of Fur on Screw Heads & Disc Rivets etc I'm_a_Newbie SV Talk, Tuning & Tweaking 4 26-10-06 10:19 AM
