Racing and Paddock Chat The latest news, talk, and gossip from the world of bike racing, you can also discuss track days here too.
Old 28-05-09, 07:35 PM   #1
rusty76
Default Track day noise tests
I know several tracks have noise tests for different events, often with the disclaimer that there's no refunds for failing the test, so I wanted to check Db levels beforehand. I've got a noise meter but does anyone know the procedure? i.e. is it 6 inch or 6 foot from the end of the exhaust?
Old 28-05-09, 07:49 PM   #2
Binky
Emily Howard rides an SV
Binky's Avatar
Default Re: Track day noise tests
It's normally something like 6 inches away at a 45 degree upward angle and at 5000rpm.
Not sure how accurate this is or whether it changes from track to track.
Does it not say in the small print of the track day website???
Wowee Zowee
Old 28-05-09, 07:53 PM   #3
rusty76
no just Db levels
Old 28-05-09, 08:33 PM   #4
simesb
days I've seen they seem to be about 6mm away, directly behind the outlet......
Old 28-05-09, 08:49 PM   #5
FG1
When I had mine tested at Snetterton it was 99db at 4500rpm.
I had a Stubbied Fuel without baffle. It was about 30cm long.
Old 29-05-09, 02:36 PM   #6
Jay12329
I've been measured at 45 degrees from 1meter at 96 and 104db. One week apart same bike! Both MSV noise testers. So i dont have much faith in them!
Sorry not much help
J
Old 29-05-09, 03:01 PM   #7
flymo
flymo's Avatar
I dont think there is a national standard that is used for track days, I do know that the ACU race regulations are pretty specific and are often copied for this purpose.
The limit for racing is 105dB at a specific rpm that is based on the type and size of engine. A 600cc 2 cylinder engine should be measured at 5500rpm and the following technique used...
The noise test will be conducted with the microphone placed at 50 cm from the exhaust pipe at
an angle of 45° measured from the centre-line of the exhaust end and at the height of the
exhaust pipe, but at least 20 cm above the ground. If this is not possible, the measurement can
be taken at 45° upwards.
The 'slow' response setting on the meter should be used.
Guidelines for the use of Sound Level Meters
1. The Sound Inspector must arrive in sufficient time for discussions with the Clerk of the
Course and other Chief Technical Officials in order that a suitable test site and testing policy
can be agreed.
2. Sound level measuring equipment must include a compatible calibrator, which must be used
immediately before testing begins and always just prior to a re-test if a disciplinary sanction
may be imposed. Two sets of equipment must be available in case of failure of tachometer,
sound level meter or calibrator during technical control.
3. Before testing, the Sound Inspector should if possible liase with another official who has
noise test equipment including calibrators, in order to agree the accuracy of the official sound
level meter.
4. Tests should not take place in rain or excessively damp conditions. Machines considered
excessively noisy must be individually tested if conditions allow.
5. In other than moderate wind, machines should face forward in the wind direction.
(Mechanical noise will blow forward, away from microphone).
6. ‘Slow’ meter response must be used.
7. ‘A’ weighted setting on sound level meter.
8. Always round down meter reading, that is: 103.9 dB/A = 103 dB/A.
9. Type 1 meter: deduct 1 dB/A. Type 2 meter: deduct 2 dB/A
10. Below 10° Celsius: deduct 1 dB/A. Below 0° Celsius: deduct 2dB/A
All tolerances are accumulative. Action taken will depend on the sporting discipline concerned, and
decisions taken during prior discussions with the Clerk of the Course.
Lid tests Blue_SV650S Bikes - Talk & Issues 2 13-06-08 09:09 AM
BBC Sport: Noise could close speedway track NewsBot News 0 25-07-07 02:00 PM
Even more from Snetterton BSB Tests Vfr400 Photos 6 31-03-07 06:20 PM
BSB Tests at Snetterton Jdubya Bikes - Talk & Issues 2 19-03-07 11:55 PM
Screeching noise? what noise does your SV make? branny SV Talk, Tuning & Tweaking 5 30-06-06 12:09 PM
