Old 29-05-09, 11:43 AM   #1
df1uk
Default Chain & Sprockets Decisions
Going to purchase a new chain and sprockets next week, currently running 14f - 44r. I do like the way the bike rides over standard gearing, especially in corners but it revs a bit more on the straights.
So thinking of going down the path of 15f - 47r as this is similar to current setup but was wondering if anyone has tried 15f - 46r compared with 15f - 47r, if so whats the differences or views on this.
Old 29-05-09, 05:23 PM   #2
Sideshow#36
Default Re: Chain & Sprockets Decisions
15-47 will ride pretty much the same as 14-44. Only difference with 15-47 is that you will definately need a bigger chain as both sprockets are larger in diameter. So you wont notice a difference in speed/acceleration etc but will in handling as the wheelbase will be lengthened. But on the other hand you will get a bit more chain life out of a 15-47 compared to a 14-44 as the turn in the chain will be smoother.
If you want it a little less revvy go for a 14-45 or a 15-46.
HTH
chain and sprockets kurtis.randle SV Talk, Tuning & Tweaking 36 11-04-09 10:26 PM
Chain and sprockets Girth SV Talk, Tuning & Tweaking 22 14-11-08 01:16 AM
New chain and sprockets CDM SV Talk, Tuning & Tweaking 20 05-07-07 11:25 AM
NEW chain n sprockets sd1cko SV Talk, Tuning & Tweaking 16 09-09-05 08:01 AM
Chain & Sprockets BaggaZee SV Talk, Tuning & Tweaking 23 12-01-05 07:07 PM
