Old 02-06-09, 01:51 PM   #1
plowsie
Default Pitted forks
Was on the CBR forum earlier, one specific member said this...
pitted forks is a MOT fail BTW.
Is that absolute tosh? Or true?
Old 02-06-09, 01:57 PM   #2
Amanda M
Default Re: Pitted forks
I know if your fork seals are leaking it's a fail - had enough ratty old bikes to know this one Not sure about just pitting though. I'd have thought that if your forks aren't leaking it'd be fine
Old 02-06-09, 02:03 PM   #3
chasey
My forks are pitted to fook and passed it's MOT.
Old 02-06-09, 02:10 PM   #4
petevtwin650
Pitted forks, as in the shiny sliders that go into the fork bottoms.
If they are pitted they can damage the fork seal as they move up and down also they may draw the oil out in the little pits and eventually you'll end up with unbalanced damping.
Old 02-06-09, 02:20 PM   #5
philbut
As Pete says, in the area of travel of the fork, pitting can mean damage to seals and leaking so could lead to an MOT failure if the examiner thought they were bad enough I guess - or if there were signs of oil on the forks indicating seal damage.
Old 02-06-09, 02:23 PM   #6
plowsie
Yeah, I can understand that, but I have never seen pitted male sections of forks (It's easier to call the two parts male and female )
Old 02-06-09, 02:43 PM   #7
philbut
you have never seen the top of my ZZR forks then It does happen, particularly where bikes aren't used that much and not kept clean - if you use them the forks clean themselves in a way by just moving over the area. The chome will eventually lift and allow rust to form, then you have to get them re-chromed really - its no good just getting out the autosol.
Old 02-06-09, 02:46 PM   #8
petevtwin650
It used to be a common sight on bikes a few years ago Plowsie, but presumably better quality plating combined with the fact most bikes are toys rather than basic tranport so get looked after better means it doesn't occur that often. A lot of older bikes used to have gaiters fitted to protect them. Of course most USD forks use the mudguard as protection. Better looking solution IMO
Old 02-06-09, 03:06 PM   #9
Kuze
ACF 50 FTW?
Also as said pitted forks will lead to the seals going fairly constantly so u'd need to replace the forks.
Old 02-06-09, 03:24 PM   #10
philbut
Nah, they aren't too bad, just the odd spot between the yolks, so not in the area of travel - was just an example of how they can become pitted if not kept clean.
front forks pitted and look bad help ! Quiff Wichard SV Talk, Tuning & Tweaking 29 28-04-10 10:18 PM
USD GSXR1000 k1 forks | standed forks - curvy Nicky S SV Talk, Tuning & Tweaking 113 07-09-09 01:12 PM
Fork Tube. Bent or pitted cloister Stuff Wanted 7 28-03-08 10:41 PM
Pitted Forks andy SV Talk, Tuning & Tweaking 1 29-05-07 08:08 PM
Restoring pitted forks Ransom SV Talk, Tuning & Tweaking 10 11-05-05 01:14 PM
