Old 05-06-09, 03:16 PM   #1
timwilky
timwilky's Avatar
Default Do I need planning permission to pitch my garage roof?
My brick garage is about 35 years old. It was in place when I bought the house 26 years ago, but had a leaking flat roof.
At that time I added 3 course of brick on one side, reroofed with corrugated steel sheets and it has just lasted.
But as my Gazebo behind is tiled, the steel roof looks out of place, and condenses in winter.
So if I was to pitch it and tile in matching tiles to the gazebo, do I need permission. It is a detached brick garage about 15ft from my house and that of the next door neighbour.
I doubt if the neighbour would complain
Not Grumpy, opinionated.
Old 05-06-09, 03:28 PM   #2
Luckypants
Luckypants's Avatar
Default Re: Do I need planning permission to pitch my garage roof?
you are proposing to raise the roof height (at least on one side) to make it pitched, so I'd expect you will need PP, but I don't know this. It may be possible that this would be within your 'extension rights' which allow you to extend by up to 15% within some parameters.
TBH Tim, you are best off phoning the planning office and discussing it. I have always found planning officers helpful and approachable, they will give you advice without prejudice.
Luckypants is online now   Reply With Quote
Old 05-06-09, 03:35 PM   #3
Spiderman
Where the hell am I?
Spiderman's Avatar
Agreed. Just dont give them your correct address in case they tell you something you dont wanna hear and feel like doing the work anyway
Old 05-06-09, 03:38 PM   #4
Owenski
I had to look into this stuff my self when building heaven (see photos) but it'l be dependent on your council Id have thought. Which council do you live in? The rules changed in Oct 2008 tobecome very very slack regarding outbuildings as their known.
For me it was I didnt planning permission provided!:
The building was not connected to the house,
It wasnt built over any existing Drainage,
It didnt increase the footprint of any existing 2 story outbuildings,
It didnt create a 2nd story on an existing single story outbuilding,
If the building was within 2m of the boundary of a naighbour then the total height was not allowed to exceed 2.5m for a flat roof,
For a pitched roof the underside of the eves was not allowed to be any higher then 2m,
If the erection is going to be within 3m of your or a naighboring house then it must have the same restrictions as above.
TBH if you dont go any higher than 2.5m you'll be fine. Thats what I've done with heaven once finished it'll be 2.35m above ground level to its highest point and tbh its 2.7x4m in size didnt need planning permission
Technically in Kirklees (where I live) your perfectly allowed to build a tower to the clouds in your back garden as long as it doesnt have a 2nd floor and it doesnt exist within 3m of either your house or the garden edge. Weird eh?
Old 05-06-09, 04:11 PM   #5
Grinch
So in Kirklees you could build a 100ft tower with just a first floor at the top, the rest is a entrance and some stairs. Nice.
Old 05-06-09, 04:17 PM   #6
RatchetJob
If its more than two metres away from the boundary with your neighbours a double pitched roof can be up to four metres measured from the highest ground around the garage.
If it is anything upto two metres from the boundary then the max height is 2.5m
For more information see here for the Government Planning Portal.
HTH
Old 05-06-09, 04:19 PM   #7
timwilky
timwilky's Avatar
It is about 6 inch from the boundary
Their ground level, is about 6 ft below my ground level. They have a nice big wall on their side and a small wall on mine
Old 05-06-09, 04:22 PM   #8
ophic
ophic's Avatar
Ever heard of Rapunzel? she was from 'uddersfield.
Silver SV650SK3, Fuel exhaust
Old 05-06-09, 04:25 PM   #9
RatchetJob
Tim,
That would mean that the height of the pitch would then have to be less than 2.5m measured from the highest ground around the garage on your side of the wall.
For example, if the ground sloped away in your garden so that it is 2.4 metres at the back of the garage and 3m at the front then that would be fine.
Old 07-06-09, 09:37 PM   #10
Owenski
Originally Posted by RatchetJob View Post
Tim,
+1 its your side that matters mate.
that tower thing would work if it were a clock tower with no elevated floor a floor would make it be classed as upstairs/2nd floor. but yeah in theory nothing to stop you putting a big brick work tower to the clouds in your garden as long as your far enough from the house and boundary and it doesnt have the 2nd floor lol.
Am sure something will stop you but not relating to the above it doesnt.
So I've got a bit of a leak in my garage roof... but there's no hole or crack? Paul the 6th Idle Banter 32 24-11-08 11:37 PM
Permission to say 454697819 Idle Banter 8 05-12-07 02:30 PM
Planning Permission furrybean Idle Banter 8 31-12-06 03:05 PM
UPDATE Pre Fab Garage.. Planning Permission ? Richie Idle Banter 28 13-12-06 09:57 PM
leaky garage roof anyone? kwak zzr Photos 18 22-04-06 07:45 PM
