Old 07-06-09, 07:29 AM   #1
BigFootIsBlurry
BigFootIsBlurry's Avatar
Default How do you care for your visor?
Because mine seems to be covered in light scratches and is generally getting a bit of a mess. I clean it wih soapy water after a ride to get the bugs off but what else should I be doing?
Ain't no sunshine when she's gone...
2000 curvy, yellow and naked. Gone but not forgotten.
BigFootIsBlurry is offline   Reply With Quote
Old 07-06-09, 08:45 AM   #2
simesb
Default Re: How do you care for your visor?
I use AutoGlym Fast Glass - spray some on and let it soak into the bugs, then spray a bit more and wipe with a mircofibre cloth.
If you "rub" the bugs off, you risk damaging the visor. Soaking and "wiping" is much better. Wash the cloth frequently - you could be dragging grit across the visor whilst you are cleaning it.
Old 07-06-09, 08:57 AM   #3
Samurai Penguin
Washing Up Liquid? That stuff is quite abrasive, which is great for getting food off your dishes but not so good for your visor
I use 'Shift It' helmet and visor cleaner and a lint free cloth. Available from Hein Gericke.
Old 07-06-09, 09:04 AM   #4
mister c
mister c's Avatar
Brilliant tip for removing flies. This goes for fairings, helmets etc.
Soak a tea cloth in water, place over infected area leave for about 10 minutes, then wipe to clean.
It does work trust me
Simples
Old 07-06-09, 09:09 AM   #5
BigFootIsBlurry
Simples
May have a go at this one, that way I can do my lid aswell. Right now its more midge than helmet
Old 07-06-09, 09:25 AM   #6
Mr Farley
For cleaning I just use a sponge with soapy water. I used to get scratches on the visor but it was mainly because I left it lying around on the floor, or forcing it in my topbox which never has enough room!
But to get rid of light scratches toothpaste can work.......if they are a little deeper then something like autsol (metal polish which is a bit abrasive) is also good . For deeper ones there's not much you can do.....replacement visor?
Old 07-06-09, 09:38 AM   #7
jamesterror
jamesterror's Avatar
Net'd sponge, cold water, doesn't scratch visor, wipe off water / left over flies with tissues or kitchen roll, then get another piece of kitchen roll and do the same again.
Scratches mean for a replacement visor, but I also have used AutoGlym Fast Glass as simesb said once or twice, but my method clears it fine
jamesterror is offline   Reply With Quote
Old 07-06-09, 09:43 AM   #8
thefallenangel
Just let the rain wash everything, bike, visor anything.
Old 07-06-09, 09:45 AM   #9
Dicky Ticker
As with the tea towel a wet tissue will suffice while you are out and about,let it soak onto the flies before wiping
I keep a small chamois leather,very wet,in a plastic bag which I lay over the visor for a minute before wiping and then polish up with a lint free cloth.
No matter how careful you are visors tend to collect surface damage with general use and if I get 12-18 months out of one I consider that I have done well.
Old 07-06-09, 10:23 AM   #10
Loz
Simples
+ one for this
Chain care SV PILOT Bikes - Talk & Issues 21 25-04-08 12:31 PM
Anti Fog Visor - Breath Guard or Visor insert Stu Bikes - Talk & Issues 50 14-11-07 10:17 AM
Care to try this Airfix Idle Banter 11 10-11-07 12:35 PM
Anyone care to explain..... Nexus242 Idle Banter 2 18-05-06 04:53 AM
Does anyone care what I look like? Jabba Photos 19 11-05-04 08:28 AM
