Old 11-06-09, 06:48 PM   #1
MG#43
Default GSXR rear shocks?
...for those that have fitted them, what do you do with the resevoir/battery tray. I've cut a hole in the bottom of mine but the battery now sits on top of the resevoir in between a piece of plastic which makes me wonder, i recon the battery now sits an inch higher at least, but i haven't checked whether the seat will nicely yet tbh?... cheers.
Old 11-06-09, 06:55 PM   #2
Bluepete
Bluepete's Avatar
Default Re: GSXR rear shocks???
You need to shave the middle lump off the seat base. I also raised the battery a few mm to clear it from the top of the resevoir. To stop the battery flopping around, II used a very heavy duty (1 cm wide) zip tie to hold it against the rear of the battery compartment.
JW
Old 11-06-09, 08:02 PM   #3
Mr Speirs
Mr Speirs's Avatar
On my curvy I just tipped the battery 90 degrees.
Old 11-06-09, 09:50 PM   #4
Red Herring
Red Herring's Avatar
On my pointy I moved the entire undertray moulding, including the battery box, back approximately 10mm. Needed to shave a bit off the back end, redrill the mounting holes by the battery, and make a couple of small alloy plates for the rear mountings, but otherwise it was easy. I use a 750 SRAD shock, or one off a 600 K4 depending on road or track and they both go straight in.
Old 12-06-09, 01:34 AM   #5
xXBADGERXx
I have a K3 with a higher subframe so I just removed the inch or so required for the reservoir , took out that bit of waffled plastic that sat in the bottom of the tray as well , plonked the battery back in with a bit of rubber under it and threw the bike back together , no problems in over a year of riding like that in all weathers
Old 12-06-09, 11:01 AM   #6
silent11
i moved the undertray back same as red herring and you cant notice a difference
Old 12-06-09, 11:43 AM   #7
mister c
mister c's Avatar
+1
Old 12-06-09, 11:55 AM   #8
CheGuevara
I moved the tray back a few mm by elongating the holes, then managed to move the battery further back by removing the plastic between the battery and the ECU.
CheGuevara is offline   Reply With Quote
Old 12-06-09, 02:54 PM   #9
rowdy
rowdy's Avatar
Wouldn't that be a fire hazard.
sorry.
Old 12-06-09, 06:53 PM   #10
boyese
which is the best year gsxr shock for the sv, as i have gsxr 600 k3-k4 forks on my bike
Differences in K4> K8 GSXR 1000 shocks Miles SV Talk, Tuning & Tweaking 2 30-09-08 10:32 AM
Rear shocks again. Lozzo SV Talk, Tuning & Tweaking 3 18-01-08 12:38 PM
Assorted GSXR Shocks For Sale Mike1234 For Sale - SV's and SV related items 4 30-07-07 11:52 AM
rear shocks stumpy1 SV Talk, Tuning & Tweaking 2 06-06-06 09:16 PM
GSXR Shocks M65 SV Talk, Tuning & Tweaking 10 29-06-05 01:45 PM
