Old 12-06-09, 12:46 PM   #1
Jackhammer
Default Question about Wheel Alignment on a K5 650
Hi there forum - quick wonderment more than anything
I helped a friend align the rear wheel on this K5 650. We got everything lines up using the guide-markings on the swing and and the nick in the triangular bracket - only the bracket on the drive side started to turn and is now out of line ....
I can see from the other side that there is a lip on the triangular bracket that in effect wedges to the underside of the swing arm to stop it from turning - on the drive side this lip appears not to sit under the swing arm - my guess is that its bent - my question is - should it be (i am hoping not)
If not then we'll simply replace it
i think i may have jus answered my own question -
but your wise thoughts would be appreciated
cheers
Jackhammer
Old 12-06-09, 01:04 PM   #2
jambo
jambo's Avatar
Default Re: Question about Wheel Alignment on a K5 650
Afternoon Mike
The markers on the K3+ bikes are effectivly bent bits of metal with a hole in the middle, so if one's bent, you can bend it back again after removing it from the bike if you want. It's not load-bearing or important and acts as a washer only, as far as the axel is concerned.
There's a fair bit of play in these anyway so they're not terribly accurate as a tool for sorting out wheel alignment, more a rogh gauge than a fine instrument.
Good luck, whatever you choose to do
Jambo
Old 15-06-09, 09:19 AM   #3
Jackhammer
cheers Jambo - may well take a 5-lb lump hammer to it hehe
Old 15-06-09, 09:48 AM   #4
Holdup
Suzuki are stupid and they made it miles to big,
Same prob on my K3 and i hate it
Wheel alignment problem. smrgup SV Talk, Tuning & Tweaking 9 08-05-09 01:49 PM
Wheel alignment question Grant66 SV Talk, Tuning & Tweaking 17 26-02-09 07:20 AM
Rear wheel alignment Maestro SV Talk, Tuning & Tweaking 18 05-01-08 05:46 PM
Wheel alignment, again muffles SV Talk, Tuning & Tweaking 4 29-07-07 12:26 AM
Wheel alignment Ratty SV Talk, Tuning & Tweaking 9 11-07-06 07:57 AM
