Old 12-06-09, 02:06 PM   #1
davepreston
Default where do i wire power from loom
for this speedo display, which wires do i conect the pos and neg wires to run the power, i dont want to run it from the battery so jumping on to the loom is easyiest but i need to know which wires to connect it to
eg: white and black wire going to blue big block connector and purple and green wire going to small blue block connector (just an example of the answer i need)
cheers people
Old 12-06-09, 02:20 PM   #2
Default Re: where do i wire power from loom
Is there an orange going up to the stock clocks?
If you need a permanent live then there is a red wire going up there. This is always on regardless of ignition switch position, some clocks need this to maintain the memory of trip counter/clock setting.
-ve is the black wire with white tracer.
Old 12-06-09, 02:22 PM   #3
davepreston
aahhh thankyou aahh thankyou very much
Old 12-06-09, 02:25 PM   #4
I will find for certain tomorrow. There is no haynes manual in this house?!?! How do people live like that, if I had house, manuals and tools would be in before sofas!
Old 12-06-09, 02:38 PM   #5
RatchetJob
Checked the Suzuki wiring diagram for a K2
Black with white tracer (there should be two, both) = -ve
Red with white tracer on loom side, red only on clock side = permanent +ve
Orange with Green tracer = switched +ve
Check it with a multi meter to confirm before attaching anything.
HTH
Old 13-06-09, 12:42 AM   #6
davepreston
mmmmm not working, will call you both idiots tomorrow before you tell me ive done something wrong and then i'll say thanks while muttering under my breath
The Wire Razor Idle Banter 5 25-07-08 06:32 PM
Unidentified wire yorkie_chris SV Talk, Tuning & Tweaking 6 15-09-07 08:46 PM
wire mesh bikerskez SV Talk, Tuning & Tweaking 3 04-02-07 11:45 AM
main fuse blows chaffing wire loom 1000homodjs SV Talk, Tuning & Tweaking 0 07-05-06 05:53 PM
Wire up switch? Bikerz SV Talk, Tuning & Tweaking 14 25-06-05 07:43 AM
