Old 13-06-09, 07:22 PM   #1
lazymanc
Default Various fastener questions.
Is it ok to replace a flange nut with a standard hex nut? I'm talking about an engine mount bolt (right hand side, bottom of the frame, M12 I think). The original is chewed up and I have some standard stainless nuts from B&Q that might do the job...
Where can I buy a dozen or so push-rivets for the fairings? I broke a fair few of them removing the panels before I discovered the "knack". I've found http://www.nyfast.co.uk/Rivets__and_...rs/Push_Rivets - I think the NRS-5080 are the closest in dimensions to the OEM ones. Problem is, they only sell packs of 1000 and £30 is a bit steep for my needs. And no, I don't fancy paying £1.50-2.00 per rivet off ebay
Generator cover bolts - are they all supposed to have washers? Mine only seems to have 2 bolts with washers, the rest didn't have them.
Finally, slightly off topic - how do you clean the old gasket scraps from the covers without causing gouges in the soft ally? I'm thinking a bit of plastic to scrape them with, maybe an old credit card?
lazymanc is offline   Reply With Quote
Old 13-06-09, 07:24 PM   #2
Default Re: Various fastner questions
I would be happy to use a normal hex nut, but would use a nyloc with a washer.
Use a gasket scraper to scrape gaskets. Or a stanly blade with the back wrapped in tape.
Old 14-06-09, 10:24 AM   #3
lazymanc
Default Re: Various fastener questions.
Cheers YC.
Bump - anyone know where I can get some push rivets?
Old 14-06-09, 06:48 PM   #4
embee
embee's Avatar
Not sure which bolt you're talking about, but the long engine mount bolt between the cyl on a curvey is a fine pitch M12 thread, so a "standard" nut might not do the job.
Black plastic rivet / fastener / clip type thing shorn Stuff Wanted 2 13-08-08 08:39 PM
need one(!) screen/fairing fastener etuna Stuff Wanted 1 20-07-08 06:57 PM
Fastener Sizes? popeye SV Talk, Tuning & Tweaking 5 31-05-08 04:43 PM
Questions questions...(funny noise,luggage, ferry) the_lone_wolf SV Talk, Tuning & Tweaking 23 23-05-07 07:19 PM
a few questions....well 5 questions....from a newb flynn209 SV Talk, Tuning & Tweaking 12 10-07-06 10:56 PM
