Old 13-06-09, 07:52 PM   #1
monkey
Default What sort of juice do heated grips pull?
Just got some heated grips and they don't specify how much juice they pull (oem, not for my bike).
Roughly how many amps will they pull on the hottest setting?
Old 13-06-09, 08:15 PM   #2
Dave20046
Dave20046's Avatar
Default Re: What sort of juice do heated grips pull?
Have you measured what your bikes charging at, at the moment? Sorry if this stating the obvious just some bikes charge worse than others so probably worth knowing before you have a figure for the hot grips.
Old 13-06-09, 08:20 PM   #3
williamturner1
My oxford suck <5a
Old 13-06-09, 08:41 PM   #4
Alpinestarhero
Oxford heated grips are 2 amps per grip apparently
make sure ur battery is ok, or the grips will deicde they dont like to work...like mine...
Old 13-06-09, 10:09 PM   #5
Dave20046
Dave20046's Avatar
and the reg rec/charging system...
Old 17-06-09, 01:10 AM   #6
Ben_K
Interesting question. I fitted my secondhand Daytona grips recently, through an ignition-linked relay (I think one of the headlight circuits in the end). Turned them on to 'start' and they heat up nicely, then flick it to 'on' and.... *pop* goes the 30A fuse in the relay. Hmm... annoying.
I can't remember now, whether I had the engine running at the time. I guess the loading on the battery may affect it without the extra current. Either way, it did confuse me that it would take over 30A!
Old 17-06-09, 10:06 AM   #7
BillyC
BillyC's Avatar
Apple.
Old 17-06-09, 11:58 AM   #8
Alpinestarhero
Originally Posted by BillyC View Post
Apple.
i dont think apple
maybe cranberry
heated grips zsv650 Bikes - Talk & Issues 6 08-12-08 11:48 AM
Heated grips skint Bikes - Talk & Issues 19 06-01-07 10:09 PM
getting heated grips off -more help please!! jenni SV Talk, Tuning & Tweaking 21 07-12-06 05:53 PM
Heated Grips NAPA121 Bikes - Talk & Issues 7 12-09-05 09:38 PM
Heated grips jimbobule Idle Banter 3 09-01-70 09:04 AM
