Old 14-06-09, 02:18 PM   #1
lazymanc
Default Fuel Pump O-ring seal, which grease?
Haynes says smear some grease - which kind should I use? LM or red rubber?
lazymanc is offline   Reply With Quote
Old 14-06-09, 03:11 PM   #2
lazymanc
Default Re: Fuel Pump O-ring seal, which grease?
I've gone for LM - Haynes also said replace the O-ring but it looked and felt like new so i've re-used it.
Old 14-06-09, 05:08 PM   #3
lazymanc
Ok, moving on - water pump coolant passage o-rings - haynes says a "suitable sealant (Suzuki bond 1207B or equivalent)". Any suggestions?
Old 15-06-09, 08:29 AM   #4
lazymanc
Will
"loctite Premium Black Silicone Gasket maker/sealant"
do the job?
What O-Ring grease (clutch cover- curvy) thedonal SV Talk, Tuning & Tweaking 12 27-10-08 01:16 PM
Water Pump seal change heirpin SV Talk, Tuning & Tweaking 2 12-10-08 09:22 PM
Fuel pump cornishrider SV Talk, Tuning & Tweaking 6 02-03-08 07:25 PM
refresh caliper seal O ring? ejohnh SV Talk, Tuning & Tweaking 8 01-02-08 11:10 PM
K5> fuel pump phil24_7 Stuff Wanted 11 29-10-07 05:18 AM
