Old 15-06-09, 06:12 PM   #1
MiszCZu
Default Abnormal engine noise?
Hello, first I will give link to the movie http://www.youtube.com/watch?gl=PL&hl=pl&v=EVSDYzn4Szc , this is my friend movie. And the question, this is normal sound of sv engine?? I've got the same noise in my sv, I change both chain tensioner and camshaft chain but it doesn't help. Any ideas ?? Sorry for my english
Old 15-06-09, 07:23 PM   #2
Speedy
Default Re: Another technical question
Do you mean the "Tick-tick-tick" noise?
I would say as it's quite a slow noise compared to engine noise at idle, that it is Cam/Timing gear noise. Camshafts rotate at half the speed of the crankshaft.
Therefore a slower noise.
Difficult though due to sound quality on video.
Dave
Old 15-06-09, 08:40 PM   #3
is there the correct amount of oil?
could be a shim needing done..
Old 16-06-09, 12:25 AM   #4
That doesn't sound normal no. Check valve clearances, also for loose clutch center nut and daft stuff like that.
Old 16-06-09, 02:34 AM   #5
Jamiebridges123
Doesn't sound healthy.. check...
Valve clearances
chamchain tensioner and stuff (most likely with that machine gun rattle)
oil level etc..
Old 16-06-09, 06:26 PM   #6
MiszCZu
Tooday I've warm up the engine and pull down the oil, 3L Should be 2,3, I ratted it back like in the service book said. Tomorow I will phone to yamaha, and give them sv to vavle clearance O I will forget, I made a movie form my engine working and the click, click, click noise make me anger
http://www.youtube.com/watch?v=YxD1hb4nn3A
Old 16-06-09, 06:28 PM   #7
But where was it in the oil window?
Old 16-06-09, 07:18 PM   #8
MiszCZu
Oil window was full, now oil is between H and L
Old 16-06-09, 07:20 PM   #9
Alpinestarhero
remember to check oil when the bike is upright (sorry if that sounds patronising, but some people havn't done it this way and easily overfilled!)
Old 17-06-09, 04:46 AM   #10
JPBiker645
Mine sounds the same how many miles\kilos do you have on the engine ... i've got 14500
Engine Noise Torn-Thorax SV Talk, Tuning & Tweaking 1 02-12-06 07:56 AM
odd noise from engine weazelz SV Talk, Tuning & Tweaking 3 01-09-06 09:11 AM
abnormal upper engine noise??? racergrrlkm SV Talk, Tuning & Tweaking 1 01-05-06 08:56 AM
Engine noise Sudoxe SV Talk, Tuning & Tweaking 6 10-07-05 10:25 PM
Engine noise SPeeeeDY Bikes - Talk & Issues 7 27-03-05 02:10 PM
