Old 18-06-09, 02:39 PM   #1
df1uk
Default O ring vs. X ring drive chains Explained - yet again.
There seems to be interest in the difference between o-ring & x-ring chains. I came across this image which will hopefully make it easier to understand.
The X ring will have two sealing points as compared to the one on the O ring.
Old 18-06-09, 04:12 PM   #2
Jamiebridges123
Default Re: O ring vs. X ring drive chains Explained
Ahh, had known of the sealing points difference but not "how" different, I see now, coool
Old 18-06-09, 04:30 PM   #3
Dan
Old before his time
Dan's Avatar
Doesn't the circular 'O' ring technically have infinite sealing points where it is in contact with the metal plates? Now there's a Physics mystery for us all to solve.
Technically, of course, if we ignore the question above, the X ring has four contact points compared to the O ring's two
Advice:
  • Rubber works best when in contact with tarmac.
  • Protective clothing helps keep the road outside and the skin inside.
http://www.DealsOn4Wheels.co.uk
Dan is offline   Reply With Quote
Old 19-06-09, 10:16 AM   #4
breakz187
Thanks for that.
breakz187 is offline   Reply With Quote
Old 19-06-09, 10:26 AM   #5
GavinD
GavinD's Avatar
my girlfriend has an x-ring SNARF SNARF!
GavinD is offline   Reply With Quote
Old 19-06-09, 11:46 AM   #6
AndyBrad
AndyBrad's Avatar
urm no?
nice piccy tho
AndyBrad is offline   Reply With Quote
Old 19-06-09, 11:58 AM   #7
GavinD
GavinD's Avatar
X ring doesn't suffer damage from being compressed as much a o-ring - e.g slightly misaligned sprockets/expansion from heat etc
Old 19-06-09, 05:52 PM   #8
This again? How many times will it be necessary to go over the differences?
Anyway, it won't matter which type, 'X' or 'O' - they're both sealed chains and do the same thing, from my own certain knowledge there is an immeasurably small difference in the performance of one type of seal to that of the other.
The difference is theoretical only, the grade of chain is the important factor, not the style of the seals.
Old 19-06-09, 09:52 PM   #9
Grinch
Hello from Portsmouth!
Grinch's Avatar
Location: Portsmouth. Rides:SV650SK1, SV650SX & SV1000NK3
Default Re: O ring vs. X ring drive chains Explained - yet again.
If you keep it lubed it should never be a problem... so the real point is... have you lubed you chain?
Grinch is offline   Reply With Quote
Old 25-04-15, 04:35 PM   #10
Longway
Longway's Avatar
Just looking a buying a new chain & sprocket set and came across this old but useful post, my question is if the lube is sealed in with O or X rings how does it let the fresh Lube in
"Ride thinking that everybody around you is trying to kill you"
Longway is offline   Reply With Quote
Spa 7th Aug, Ring 8th/9th Aug Tim in Belgium Track Days 7 10-08-09 07:26 PM
Chain and Sprockets & X-ring vs o-ring? thor SV Talk, Tuning & Tweaking 38 20-06-09 01:59 PM
Lap of the Ring from last weekend Tim in Belgium Photos 14 27-05-09 07:02 PM
A nice ring... Stingo Idle Banter 5 06-03-06 02:47 PM
X Ring vs O ring Iansv SV Talk, Tuning & Tweaking 13 03-04-05 09:43 PM
Powered by vBulletin® - Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
