Old 14-07-09, 08:31 PM   #1
quikstu
Default MOT advisory notice.
Took my '03 plate' 650s for it's MOT yesterday & it passed without major problem.
I did get 4 advisory notices one of which I have a query about.
Also what nut do I tighten to sort the problem?
The notice was "Centre (swinging arm) Rear suspension bush has slight free play".
Can anyone point me in the right direction of where to start???
Thanks in advance.
Stu
Old 14-07-09, 08:35 PM   #2
tanis34
Default Re: MOT advisory notice.
snap i had th same on mine on wed lol
Old 14-07-09, 08:38 PM   #3
Well the language used isn't plain, but from what's said I imagine it's referring to the bushes in the swingarm upon which pivot the links, (often called 'dog bones'), that connect it to the suspension linkage.
Specifically the bearings numbered 4, in this diagram,
and the bush numbered 15, in this diagram.
Old 14-07-09, 08:46 PM   #4
tanis34
all he said to me was give the nut a quick tighten up
Old 14-07-09, 09:36 PM   #5
The bearings aren't adjustable - unless the parts are actually loose tightening the fittings won't do any good.
Old 15-07-09, 06:18 AM   #6
Swin
Swin's Avatar
my bandit had 2 advises for excess play in the rear suspension, it was only when it started making a lot of noise that I started to look at it, but as SS says, it wasn't adjustable, needed 2 of the bushes replaced to cure it
Swin is offline   Reply With Quote
Old 15-07-09, 11:31 AM   #7
Cam_73
So would that mean replace with new or could it be shimmed if tightening the nut wont do any good?
I think this came up second to last MOT i had at Victor Devine, they mentioned it. Suggested that it's probably there from the factory but will get worse with age/use.
Old 15-07-09, 12:52 PM   #8
No, the suspension has only needle bearings in it*, there's nothing to shim, if there is play in the suspension something needs to be replaced.
*Two that the swingarm pivots on, two in the underside of the swingarm at the top end of the links and four in the linkage.
Old 16-07-09, 10:26 AM   #9
SV650Racer
You have a bearing that sits either side of the main swingarm spindle bolt that runs through the frame. You need to nip back and ask which one he meant.
Old 21-07-09, 08:31 PM   #10
quikstu
Thanks guys. Will head back to confirm with the tester once it stops pouring wi rain!
Cheers.
MOT Pass, but Advisory note. krhall Bikes - Talk & Issues 12 05-11-07 02:17 PM
FYI Sys admins: 3ware Customer Advisory philipMac Idle Banter 0 25-06-07 08:37 PM
notice anything new? hovis Idle Banter 21 11-04-07 03:05 PM
Brake light - MOT "advisory" seedy100 SV Talk, Tuning & Tweaking 12 03-06-06 06:14 PM
Will I notice any difference? Red ones Bikes - Talk & Issues 32 25-03-05 09:48 AM
