Old 18-07-09, 09:26 PM   #1
Demonz
Default Are Clocks Requirement to Run?
Kind of an odd question as its a project, but are clocks a requirment for the bike to run? I mean if they are unplugged will the bike be able to start/run?
I have a curvy which didnt come with a sub-loom so I just wired the kill switch back into the main loom and it ran fine. I picked up another sub-loom and have put all the wiring back like it should be (still missing clocks though) and now I doesnt start. Before I study the electrical guide and re-check all the wirining - just thought I'd ask...
Old 18-07-09, 09:33 PM   #2
dirtydog
Knob faced knobster
dirtydog's Avatar
Default Re: Are Clocks Requirement to Run?
Curvey should still run with no clocks, it's the pointies that don't AFAIK
2011 Speed Triple 1050
Old 18-07-09, 09:37 PM   #3
cammy
I started mine today without clocks as long as you have the hand controls plugged in so the clutch switch works i just jumbed the switch with a piece of wire but maybe it would have started anyway because the stand was up and in neutral
Old 18-07-09, 10:02 PM   #4
Stu
Trinity
Stu's Avatar
Anther confirmation that TSM runs his curvey on track, sans clocks
Old 19-07-09, 09:21 AM   #5
Demonz
Thanks for the comments to confirm.
I guess its a good start point with the clutch. Didnt check this one.
Old 19-07-09, 09:23 AM   #6
Demonz
....OK and one more I should have also asked. Are the clocks required for the headlights to work as well? I noticed no power coming through to these as well.
Old 19-07-09, 09:59 AM   #7
21QUEST
21QUEST's Avatar
No
Ben
Nemo me impune lacessit.
Old 19-07-09, 12:04 PM   #8
dubno
Pointies don't need the clocks to run.
If you don't have power to the lights then perhaps a more fundamental problem. Fuses
Do the other electrical bits such as horn/indicators work. All of that stuff is a pretty basic circuit so if those aren't working then you need to check the simple stuff first. Once that works, not starting is likely to be clutch/sidestand switch etc.
Good luck!
Clocks or no Clocks Demonz SV Talk, Tuning & Tweaking 15 04-07-08 03:55 PM
URGENT Requirement! Curvey rear coil and plug lead. jamessunhill Idle Banter 2 27-06-08 01:03 AM
Clocks jon holt SV Talk, Tuning & Tweaking 5 04-05-07 01:04 PM
clocks dirtydog For Sale - SV's and SV related items 0 09-03-06 05:14 PM
MOT & legal requirement issues haggis Bikes - Talk & Issues 5 23-02-06 08:51 PM
