Hi everyone with this been my first bike i don't have any experience with adjusting the pre load on the suspension anyone got a good base setting i could start with then move on from there, i'm 6ft and just under 14st if thats any help.
About the same as me weight wise. I just wound it in one notch at a time;
front first, then rode for a bit to get used to it, wound rear in a notch and rode again. Am now two notches in from stock settings front and rear and am happy with it for daily commuting, and the odd twisty fun ![]() I'd suggest one notch at a time and see how you go for your riding style etc. Have fun. |
Remember to only change one thing at a time
![]() Can't remember the exact stock settings, but it's about middle of adjustment for each. |
Stock 3 on front, Rear i believe is 4 on S model and 3 on naked model.
i used this http://www.gostar-racing.com/informa...ion_set-up.htm but only using the preload guides obviously, only done front so far, cables ties on both forks (i did any way can only do 1 if you want), lose but not too loose just so no damage caused to stanchons or seals, add/remove a click each time, go for ride, messure the distance from bottom of cable tie to bottom yoke, each time you add remove a click, reset the cable tie, then once there is 10mm between cable tie and yoke, ![]() HTH |
#5 | |
what a load of old cobblers..... | dizzyblonde | Idle Banter | 21 | 12-03-09 04:05 PM |
Pre-Load Adjusters | PaulyMac | SV Talk, Tuning & Tweaking | 4 | 06-12-06 10:44 AM |
Get a load of this! | Jabba | Idle Banter | 5 | 30-11-06 12:52 PM |
What a Load of ...... | Marshall | Idle Banter | 8 | 26-05-06 01:20 PM |
pre-load adjusters | jayjay | SV Talk, Tuning & Tweaking | 2 | 17-04-06 03:05 PM |
