Old 20-07-09, 08:29 AM   #1
Grinch
Default Clutch whine/slip.
Well I changed the chain and sprockets over the weekend and got Helga through another MOT. Surprised me I tell you, not even any advisories.
But I digress, I thought the chain and sprockets change had resolved the clutch slip that I was getting, but no. On the way back from the MOT it came back. Slips only in first gear, and when it does there is a touch of whine to it. A loud-ish 'eeeeeeeeeh' noise, and then sometimes like my journey this morning it was fine.
So can anyone advise what could be causing the slip and whine and where I should be looking.
Old 20-07-09, 09:07 AM   #2
flymo
flymo's Avatar
Default Re: Clutch whine/slip...
Is it properly adjusted at the clutch actuator Grinch?
Old 20-07-09, 09:10 AM   #3
Grinch
Well I think so, as when I changed the chain and sprockets, I also took it off, greased it, lubed the cable and then re-adjusted it all. Either that or my adjustment made it worse.
Old 20-07-09, 09:32 AM   #4
flymo
flymo's Avatar
might be worth removing the clutch cover and having a good look at the springs/plates. You'll need a new gasket handy for refitting though. If you tilt the bike to the left on its sidestand you should be able to do it without dropping the oil.
Might be worn plates, tired springs or even a loose spring fastener. Assuming its the clutch at fault.
Old 20-07-09, 09:50 AM   #5
Grinch
I hope not, I only just swapped all that.
Old 20-07-09, 09:51 AM   #6
Viney
Is the noise when you let the clutch out? If so mine does that occasionaly and a top up of oil usualy cures it. However i do think my clutch is on its way out and has been for a while to be honest.
Old 20-07-09, 10:18 AM   #7
Grinch
Yep, as I pull away. I know that these bikes can get a bit of clutch whine and slip, though this seems excessive to me.
Old 20-07-09, 10:29 AM   #8
flymo
flymo's Avatar
what kind of oil are you using?
Old 20-07-09, 10:35 AM   #9
jambo
jambo's Avatar
Once you're moving, do you get any clutch slip by loading the engine hard in 1st / 2nd / 3rd without touching the clutch lever, or is this only when pulling away?
Jambo
Old 20-07-09, 10:49 AM   #10
Grinch
Only ever pulling away, so far all the other gears have been fine.
I'm currently running Halfords oil, semi-sith.
Clutch slip in first gear and a gas smell stone SV Talk, Tuning & Tweaking 12 13-05-09 03:47 AM
clutch slip with syn. oil - help! glang SV Talk, Tuning & Tweaking 10 12-04-09 11:03 PM
Does the sv whine? AndyBrad SV Talk, Tuning & Tweaking 36 19-09-08 12:25 AM
Clutch Slip After Accident- Maybe? ScottishRawker SV Talk, Tuning & Tweaking 17 15-08-07 07:40 PM
Transmission Whine Ming SV Talk, Tuning & Tweaking 5 02-08-06 08:48 PM
