Old 20-07-09, 11:03 AM   #1
Grinch
Default Indicator resistors or new flasher.
Now, I've replaced the indicators on my other SV with LED's and as you can imagine the flash rate is a touch high.
I was looking at putting in the resistors, which I will need one for each led, or does anyone know of a flasher I could use to replace the original with. So save a lot of hot resistors being wired into the bike.
Old 20-07-09, 11:53 AM   #2
jambo
jambo's Avatar
Default Re: Indicator resistors or new flasher.
I believe Motrax / GB Moto do flasher relays from Halfords and other outlets. They should be plug & play and I imagine replace the charge / discharge cycle which involves the resistance of the bulbs for timing with an internal timing circuit. Easy, but much dearer than a couple of extra resistors.
Jambo
Old 20-07-09, 12:17 PM   #3
Grinch
Yep I'm more then happy to get a few resistors and wire them in.
Old 20-07-09, 12:28 PM   #4
mattSV
mattSV's Avatar
Dan
I had resistors on my SV1000 for 4 years with no problem - IIRC they were 10w 10ohm from Maplins, about 40p each, one for each indicator - might evan have a couple of spares at home still if you need them.
Matt
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 20-07-09, 12:49 PM   #5
Grinch
I'll be poping down to Maplins later, but thanks for the offer.
Old 20-07-09, 12:50 PM   #6
SoulKiss
SoulKiss's Avatar
I'd go for the flasher rather than the resistors any time, I dont like the idea of hot pieces of metal buried away in the plastics/underseat of the bike.
Old 20-07-09, 12:58 PM   #7
Grinch
Depends on where I mount them... I'm sure something will come to mind.
Old 20-07-09, 01:06 PM   #8
SoulKiss
SoulKiss's Avatar
If you really must, make sure they are well insulated (to avoid a short) and jubilee-clip them/epoxy them to the frame as a heat-sink.
Old 21-07-09, 08:36 AM   #9
Grinch
Mmmh epoxy.
resistors for indicators sv650nutter149 Stuff Wanted 2 08-02-09 08:39 PM
SV Indicator flasher unit ? Dave20046 SV Talk, Tuning & Tweaking 6 05-02-09 01:22 PM
Mini-indicator question (not resistors :P) Baph SV Talk, Tuning & Tweaking 22 20-03-07 09:08 PM
resistors for lED indicators Quiff Wichard SV Talk, Tuning & Tweaking 13 27-04-06 07:00 PM
Signal Resistors... ahlb0018 SV Talk, Tuning & Tweaking 7 17-02-05 10:02 AM
