Old 22-07-09, 12:22 PM   #1
AndyBrad
Default oxford heated grips relay
Ok after having a slight issue with a flat battery and my grips being "off" im going to wire them up through a resistor. Wheres the best"easiest" place to take a feed from for the relay?
its a 99 curvy btw
Old 22-07-09, 12:39 PM   #2
Lozzo
Default Re: oxford heated grips relay
If you wire them correctly through an ignition switched live, there's no need for resistors or relays. I tapped off the fused side of the horn feed wire to fit mine.
Old 22-07-09, 01:08 PM   #3
AndyBrad
Well i wanted them to be on a relay so if they do have any problems its not going to effect something else on the bike.
Old 22-07-09, 10:06 PM   #4
PaulSV
I wired mine straight off the battery and have never had a problem, maybe it's something else thats causing your flat battery.
Old 23-07-09, 02:10 AM   #5
ridelikeaturtle
its a 99 curvy btw
The rear tail light.
See it all laid out here: http://www.canyonchasers.net/shop/generic/relay.php
Enjoy.
Old 23-07-09, 06:33 AM   #6
Spanner Man
Good morning.
I prefer to wire such accessories as heated grips through a fused relay, as this ensures that the operating current comes straight from the battery, & adds another level of protection.
As the main live comes from the battery, & ther other live to the relay is only there for operating it, you can wire it into any circuit that is live with the ignition switched on. Avoid annything to do with the ignition system itself, & chose something like the feed to the rear brake light switch, or as suggested the tail light feed. If using this then obviously your grips will only work when the lights are on.
Cheers.
Spanner Man
Old 23-07-09, 06:35 AM   #7
AndyBrad
brilliant thanks. after lots of faffing last night ive discovered my 80 quid mm is bust! gutted although im sure my batterys not giving out 200v
Oxford heated grips Clone Bikes - Talk & Issues 6 18-09-08 04:21 PM
Oxford heated grips SDMF Thames Valley 3 14-12-07 09:59 PM
wiring up oxford heated grips hovis Bikes - Talk & Issues 23 07-11-07 08:01 PM
Wanted - Oxford heated grips svrash Stuff Wanted 0 02-10-06 11:36 PM
oxford heated grips didge Photos 0 12-09-05 07:16 PM
