Old 22-07-09, 06:09 PM   #1
Loser
Default Throttle movement question when fitting r6 twistgrip
As the title, before i fitted the r6 throttle i noticed that when the standard twistgrip is fully open i can reach into the throttle body and move it a little more until it "clicks". In other words the twistgrip doesn't move the throttle body fully between its limits. So when i fitted the r6 twistgrip i left it the same.
assuming what i have said is understandable, should the throttle body move completely between its limits when the twist grip is open fully?
thanks
Old 22-07-09, 06:10 PM   #2
simesb
Default Re: Throttle movement question when fitting r6 twistgrip
Sounds more like your cables are badly adjusted to me.
Old 22-07-09, 06:12 PM   #3
Loser
cables have always been adjusted as per the workshop manual however i have now adjusted them so that the throttle body does open lock to lock if this is how it's supposed to be.
thanks
Old 23-07-09, 10:02 AM   #4
21QUEST
21QUEST's Avatar
Curvy or Pointy?
Ben
Nemo me impune lacessit.
Old 23-07-09, 11:25 AM   #5
Loser
it's a pointy - i now have less freeplay in the twistgrip but its fine - i guess i really just wondering if the throttle body should deffo move from stop to stop
Old 23-07-09, 12:25 PM   #6
21QUEST
21QUEST's Avatar
Thought it might be. Take a look at the link below as I reckon that might be your problem.
http://forums.sv650.org/showthread.php?t=83740
Ben
Old 23-07-09, 02:17 PM   #7
Loser
thanks for that - so it's a matter of taking a little more off the tube most likely or i could probably get a liitle more freeplay by loosening the cables and readjusting from the throttle body end
It's a nice mod and really makes full throttle so much easier now - so even more self control is required around town - it also does make the throttle slightly more twitchy but thats not really a problem
R6 throttle tube but not the usual question. Mark_h SV Talk, Tuning & Tweaking 5 09-04-09 09:50 PM
disc movement Dave20046 SV Talk, Tuning & Tweaking 23 30-03-09 05:54 PM
Fitting R6 Throttle(Encountered Problems) plowsie SV Talk, Tuning & Tweaking 10 30-04-07 08:05 AM
Throttle / Revs sticking (and now brake question) goof SV Talk, Tuning & Tweaking 15 12-06-06 09:54 AM
Throttle body question Joe110 SV Talk, Tuning & Tweaking 2 20-01-06 10:53 PM
