Old 22-07-09, 08:17 PM   #1
Lego
Default Removing a clip on - how?
I have an SV650 SK5, and am trying to replace the L/H clip on, was wondering if someone could advise me on the method I should undertake... (Not sure if in correct area with this)
Any help would be great
Many Thanks
Dan
Old 22-07-09, 08:27 PM   #2
simesb
Default Re: Need Help!
Remove the cable from the lever, and the switchgear from the clipon
Loosen the clipon bolt
Loosen the 3 fork clamps
Drop the fork until you can get the clipon out.
Or something close to that.
Make sure the bike is properly supported, and I guess you'd need to take front wheel/fender off.
Old 22-07-09, 08:51 PM   #3
Ruffy
Ruffy's Avatar
Off the top of my head, I think I'd just take off the top yoke. (No need to drop the wheel or undo the head bearings.)
Loosen the top clamp bolts on both sides, undo the top clap bolt and lift off (watch out for limits of ignition switch wiring etc.), then remove clip on after removing switchgear etc.
Spannering the wife's SV650S K5 pointy in Black, and son's SV650 X curvy in Blue.
RIP SV650 X curvy, crashed and written off December 2019.
I'm (procrastinating about) fixing up an old Yamaha FZ600 to get myself fully back on the road.
Ruffy is offline   Reply With Quote
Old 22-07-09, 08:58 PM   #4
thefallenangel
Headstock stand, take off front left caliper and slacken off the wheel spindle to lower the fork and replace.
Old 23-07-09, 09:03 PM   #5
Lego
Talking Re: Removing a clip on - how?
Thanks for the help guys! greatly appreciated!
I thought of the same way as you Ruffy but; I borrowed a headstock stand off TFA. So took off caliper and mudguard (left side), left the wheel in spindle from the right, drop the fork about two and half inches and swapped over the clipons... Clamped back up and was riding in half hour after getting out of car with stand
Thanks again!
Dan
TLS clip-ons !! drag Stuff Wanted 2 22-04-09 11:10 AM
K3 S clip ons flymo Stuff Wanted 1 01-03-08 04:19 PM
Clip ons markmoto Stuff Wanted 4 19-07-07 09:01 AM
Clip-ons....(from flat bars to clip-ons) Gnome SV Talk, Tuning & Tweaking 6 12-07-07 06:57 PM
LH clip on ivantate Stuff Wanted 0 03-08-06 06:33 AM
