Old 23-07-09, 10:05 PM   #1
Daps
Default Tail tidy woes; rounded off screwhead, then dropped!
Hi Everyone
New to the forum; got my SV after passing my test on Monday and... ballsed up already!
Fitted the OEM seat cowl with no troubles this eve and then set to work on the tail tidy. Got both seats off and then, whilst trying to undo a really tight screw holding the rear fairing on, managed to round it off
It gets better though; after giving up and putting it back together, i managed to drop it!! Argh!! And then pulled a muscle picking it back up again!! Luckily I only broke the front right indicator casing (now gaffa taped together) and scratched the screen (which i'm replacing with a double double anyway). A £16 trip to Fleabay will sort the indicator however...
What do I do about the rounded off screw head?! Am i as stuck as i think i am?!
Yes I am a moron; what an introduction to the forum!
Daps
P.S. Picture of my baby before I was a complete ditz...
Old 23-07-09, 10:10 PM   #2
Spiderman
Where the hell am I?
Spiderman's Avatar
Default Re: Tail tidy woes; rounded off screwhead, then dropped!
Hello and welcome, i see you got one of those "primer-only" finishes...so what colour you gonna paint it?
Sorry to hear of the drop, dont worry we've all done it and some of us more than once.
As for the screw you rounded off...hmmm.... got a pic? Ive heard of bolts being rounded off and there are ways to sort that.
Old 23-07-09, 10:14 PM   #3
flymo
flymo's Avatar
Hi Daps, dont worry we've all been there at some point or other.
Can you post a pic of the rounded screw?
All depends on how much access you have to it but most important thing is to avoid damaging the fairing itself as you try to remove it. Normally I would attempt to cut a straight groove across the screw head and use a flat blade screwdriver to remove it.
Depends where the screw is and how much access you have to it.
Old 23-07-09, 10:16 PM   #4
What head does the bolt have?
All's not lost, impact drivers a good tool as it bangs and well as twists (ooh err)
Maybe post a pic of the offending bolt.
Old 23-07-09, 10:18 PM   #5
Kilted Ginger
I recently did a complete strip and 4 of the bolts rounded, one i drilled out, one screw extractored, one chiseled and one mole grips, it really does depend on what type and where it is, like the others habe said a few good clear photos will help.
oh welcome btw.
Old 23-07-09, 10:20 PM   #6
Daps
I quite like it in silver, though granted it's a bit flat. And yes, bar the indicator my pride took the biggest dent (lesson learnt: no rear grabrail + pathetic weak arms = sitting on it and scooting it about rather than wheeling it from the side!)
I'll take a pic of the screwhead tomorrow - it's not *completely* rounded but after several attempts with different heads and some mole grips only made it worse, I thought i'd seek advice from people with more than half a brain-cell i.e. not me!
Thanks in advance guys
EDIT: it's a just a crosshead, pics to follow, ta!
Old 23-07-09, 11:10 PM   #7
Spiderman
Spiderman's Avatar
if its easy to get at then i would suggest you go soak it in wd40 if you can. it'll help whatever you have to do to get it out and give it time to penetrate well.
Silver ones never look dirty tho, so you got it easy
Old 25-07-09, 12:10 AM   #8
joshmac
Raf's does!
Old 29-07-09, 12:05 AM   #9
Daps
Well, a stripped screw head is the least of my worries. I came off tonight
Luckily it was low speed so I'm mostly unhurt (right shoulder hurts and shaken up but nothing major), but God knows how much it'll cost to get my bike fixed. At <30mph I just lost concentration braking for a corner; the back locked up and by the time i got it together I was heading straight for the opposite kerb. Went up the kerb, down onto a side road, and then the bike flung me off and went down on its side.
A kind passer by ran over to check I was alright and picked the bike up for me. I *think* i've been lucky and, bar some minor cosmetic stuff (scuffed fairing and scratched exhaust), only the right hand bar and wing mirror will need replacing. The indicator was broken anyway after my last f*** up. It road home fine so I've got my fingers crossed that it won't be a horrendous repair bill
Damn.
Old 29-07-09, 12:07 AM   #10
Holdup
you dont seem to have much luck, glad your ok though
Curvy tail skirt or tail tidy mouldy Stuff Wanted 3 21-02-09 12:49 PM
Tail Tidy Crammy15b Stuff Wanted 3 03-05-08 09:35 AM
evotech tail tidy woes eano2 SV Talk, Tuning & Tweaking 15 04-09-07 10:31 PM
Evotech tail tidy woes adw SV Talk, Tuning & Tweaking 9 20-06-07 07:37 AM
Tail Tidy. Tail Tidy...Sell me your Tail Tidy.... 1world2wheels Stuff Wanted 7 15-07-06 10:09 AM
